Visual LISP, AutoLISP and General Customization
Macro for rotating text to a line
3 REPLIES 3
allywhite666
510 Views, 3 Replies
I would like a macro that will rotate any text to a line with just two clicks.
At the moment I am selecting the text and then rotate,
then I have to pick a base point,
then press R for reference and select the two bottom corners of the text,
then I have to press P for points to pick two points on the line I want to align it to.
Does anyone have a macro that I can assign to a short cut key and just select the text and then the line, or even just select the text and then two points on the line, but would prefer the first.
I appreciate any help you guys can give me.
Thanks Heart
3 REPLIES 3
_Tharwat
in reply to: allywhite666
use align command and that is less in steps than the one you are describing .
3wood
Please try TORIENT command in Express Tools. It does exactly what you want.
allywhite666
Thank you both for your help, the TORIENT command is the solution I was looking for.
”Boost
