Visual LISP, AutoLISP and General Customization
Locked viewport command
3 REPLIES 3
sssteve72
542 Views, 3 Replies
^C^C-layer;m;VPORT;c;81;;p;n;VPORT;;_vports
^C^C-layer;m;VPORT;c;81;;p;n;$M=$(if,$(eq,$(getvar,tilemode),0),^C^C_-vports _p,^C^C^P(ai_viewports_alert)^P)
A long time ago I had made a button with the above macro (actually there are two buttons there) to basically make a viewport and always put it in a specific layer with a specific color etc..  Well since then I've discovered I'd like to make that same viewport locked as part of the command so that when I initially draw the viewport it is locked.  I am not good with code and I know I didn't make that second one as that is way beyond me.
Is there a way to code a locked viewport without picking on it or typing in a name so that I basically click my command button and draw my viewport and when I am done everything in my macro up above is done and the viewport is locked?  Does anyone have anything like this ?
Custom Build with Win7 Pro 64Bit SP1
Gigabyte Tecohnology Co. X79-UD3
3.60 gigahertz Intel Core i7-3820
16GB GSkill Ripjaw Z PC3 2133 PC17000
PCI-E ATI FirePro V7800 2GB 256bit
ATA SanDisk SDSSDX24 SCSI Disk Device (256 GB)
Dell 2001FP, 2407WFPHC, ASUSVN289 in Triple monitor setup
Question - Are you the Common Denominator?
3 REPLIES 3
scot-65
in reply to: sssteve72
A quick and dirty LISP...
(if (= (getvar "TILEMODE") 0)
(command ".VPORTS" "Lock" "On" (ssget "A" '((0 . "VIEWPORT"))) "")
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
smaher12
The following will create your layer, with the viewport on that layer, and then lock the viewport...
^C^C-layer;m;VPORT;c;81;;p;n;VPORT;;VPORTS;\\VPORTS;LOCK;ON;LAST;;
sssteve72
in reply to: smaher12
I couldn't get scot's to work (probably something I did wrong) but this one works great, thanks smaher12.
”Boost
