To load layers not present, just insert a base dwg, easyest way.
If you want to redefine layers you may want to do that with a simple
routine, depends on the number of layers you use how long the prog. becomes.
A typical code line would look like this:
-LAYER;M;HATCH;C;6;
The trick is in the M from MAKE, line can be expanded to set L
(linetype), LW (lineweight) etc.
Jan
John G wrote:
> Hey all,
> I'm looking for a way to load a predefined set of layers from a list,
> like an ini file or something. Is there a way to do this and also have it
> overwrite any other layers with the same name so if someone loads the
> layers, changes something about them, and then reloads them, they will go
> back to what they should be per the master list???
> Hopefully that makes sence.... thanks all
> John G.
