Can a VLX be loaded and run with a single command? Command "dxedel" here is defined in DXEdel.vlx, but it won't run just like that.. The VLX loads fine when "dxd" is run, but i get 'unknown command' when "dxedel" should be executed. Thank you!
(defun c:dxd ()
(vl-load-com)
(load "DXEdel")
(command "dxedel")
(princ)
Solved by hmsilva. Go to Solution.
how to apply selection set for a loaded lisp command "Iburst"? (c:iburst xxblks) is incorrect:
(defun c:bss1 () ;; iburst blocks "l1" and "z"
(load "BurstUpgradedV1-2_IBURST.lsp")
(if (setq blks (ssget "_x" (list '(0 . "insert") (cons 2 "l1,z,`*U*"))))
(progn
(setq i 0
xxblks (ssadd)
);; setq
(while (setq hnd (ssname blks i))
(setq blkn (vla-get-effectivename (vlax-ename->vla-object hnd)))
(if (wcmatch blkn "l1,z")
(ssadd hnd xxblks)
);; if
(setq i (1+ i))
);; while
(if xxblks
(c:iburst xxblks)
);; if
);; progn
);; if
(princ)
I don't have that function to try it, but one way that kind of thing is sometimes done is to have the selection set selected/gripped/highlighted as a pre-selection, and then apply the command:
(if xxblks
(progn
(sssetfirst nil xxblks)
(c:iburst)
); progn
);; if
