You don't necessarily need access to the application.
Make a backup of the current DCL file, and replace its contents with the
following that I cleaned up a little because of word-wrap. Unless the
application's dialog is defined internally, this should work.
select_sites : dialog {
label = "Site Volume Librarian";
: row {
: column {
: list_box {
width = 20;
height = 15;
fixed_width = true;
key = "1";
label = "Select site: ";
// Set the value to "0"
// to focus on the first item...
value = "0";
allow_accept = false;
list = "";
multiple_select = false;
: column {
fixed_width=true;
width=20;
: column {
fixed_height=true;
spacer;
spacer;
: button {
label = "Select All";
key = "2";
: button {
label = "Clear All";
key = "3";
spacer;
ok_cancel_help;
errtile;
John Uhden, Cadlantic/formerly CADvantage
http://www.cadlantic.com
Sea Girt, NJ
"lorier" wrote in message news:f141bd7.1@WebX.maYIadrTaRb...
> please excuse my dcl ignorance, but i don't have access to the application
that loads the dcl, Is that where the tile definition would go?
