Visual LISP, AutoLISP and General Customization
List showing handle, color, and byblock or bylayer?
5 REPLIES 5
423 Views, 5 Replies
I need to make a list of all plines. For each pline I need to extract 1.
the entity handle, 2. the color, and 3. whether that color is by layer or by
block.
I'm somewhat bothered by the object data insofar as color is concerned.
(setq EntObj (vlax-ename->vla-object EntName))
From EntObj I read both index color and true color.
I need to know which it is. I also see nothing in EntObj about whether the
color is by layer or block.
Any suggestions?
Len Miller
To email reply, eradicate all threes in my SPAM guarded address.
5 REPLIES 5
_gile
Hi
Is this good for what you need ?
(defun c:pline->list (/ ss n pl e_lst lst)
(setq ss (ssget '((0 . "LWPOLYLINE"))))
(if ss
(repeat (setq n (sslength ss))
(setq pl (ssname ss (setq n (1- n)))
e_lst (entget pl)
lst (cons (list (cons 1 (cdr (assoc 5 e_lst)))
(cons 2 (cond
((= (cdr (assoc 62 e_lst)) 0)
"BYBLOCK"
((or (null (cdr (assoc 62 e_lst)))
(= (cdr (assoc 62 e_lst)) 256)
"BYLAYER"
(T (cdr (assoc 62 e_lst)))
lst
(mapcar 'print lst)
(princ)
Gilles Chanteau
GileCAD
GitHub
Gile,
Great work. You've got two out of the three, the handle and the
ByBlock/ByLayer state. I'm now trying to get a sense of your flow to see if
I can figure the color, specifically when it's a True Color value.
Thank you.
Len
wrote in message news:5301753@discussion.autodesk.com...
Hi
(if ss
e_lst (entget pl)
(cons 2 (cond
"BYBLOCK"
"BYLAYER"
lst
(mapcar 'print lst)
(princ)
For what it's worth, attached is my test drawing with a variety of plines,
colored in different ways.
Len
Hi
(if ss
e_lst (entget pl)
(cons 2 (cond
"BYBLOCK"
"BYLAYER"
lst
(mapcar 'print lst)
(princ)
How about something like this?
[code]
(defun poly_list (/ ss obj tmp master)
(if (setq ss (mapcar 'cadr (ssnamex (ssget "x" '((0 . "LWPOLYLINE"))))))
(progn
(foreach ent ss
(setq obj (vlax-ename->vla-object ent)
color (vla-get-truecolor obj)
method (vla-get-colormethod color)
(cond ((= method acColorMethodByLayer)
(setq cType "Bylayer"
colorNum 256)
((= method acColorMethodByBlock)
(setq cType "ByBlock"
colorNum 0)
((= method acColorMethodByRGB)
(setq cType "RGB"
colorNum (list (vla-get-red color)
(vla-get-green color)
(vla-get-blue color)
((= method acColorMethodByACI)
(setq cType "ACI"
colorNum (vla-get-entitycolor color))
(t
(setq cType "ForeGround"
colorNum "NotSureAboutThis")
(setq tmp (list (vla-get-handle obj)
colorNum
cType
(setq master (cons tmp master))
[/code]
"Fatfreek" wrote in message
news:5303109@discussion.autodesk.com...
Len
Hi
(if ss
e_lst (entget pl)
lst (cons (li
(cons 2 (cond
"BYBLOCK"
"BYLAYER"
lst
(mapcar 'print lst)
(princ)
Beautiful, Jeff. I am forever grateful.
Len.
"Jeff Mishler" wrote in message
news:5303209@discussion.autodesk.com...
[code]
”Boost
