Visual LISP, AutoLISP and General Customization
List of Workspaces
3 REPLIES 3
trevor.bird.au
877 Views, 3 Replies
List of Workspaces
Hi All,
Please find attached my take on retrieving a list of Workspaces from menu files .cui and .cuix
The function to use is (workspacelist) which returns a list of workspace names, similar to (layoutlist) for retrieving a list of Layout names.
The functionality for extracting "WorkspaceRoot.cui" from .cuix requires copying the .cuix to .zip so that it can be accessed as a Windows compressed (zipped) folder which the Windows object "Shell.Application" provides.
Please rename the attachment to .lsp
I received the following error when I tried to post the .lsp: "The contents of the attachment doesn't match its file type."
If possible, I would appreciate some advice on this error when posting .lsp files.
Thanks.
Trevor
Tags (2)
3 REPLIES 3
hmsilva
in reply to: trevor.bird.au
Many thanks for sharing your code Trevor. Smiley Happy
The "The contents of the attachment doesn't match its file type." sometimes happens and is a known issue by Autodesk, they are trying to fix it. Smiley Sad
Henrique
trevor.bird.au
in reply to: hmsilva
Hi Henrique,
Thank you for your reply and your advice about uploading.
Trevor
scot-65
I usually append a ".txt" to the file name when sending out:
WorkspaceList.lsp.txt
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
”Boost
