smaher12
Message 1 of 4 (207 Views)
list issues for a popup list
207 Views, 3 Replies
01-02-2014 06:19 PM
How do I get this hatch pattern list to work in this dcl. Do I need to convert the pattern name to a number? I am pretty lost on what to do next on this.
(defun c:ww ()
(defun dfaults ()
  (if (= dia nil) (setq dia 1.0))  ;;; Dialog Menu Presets
  (setq names '("Ansi31" "Ansi32" "Ansi33"))
  (if dia (set_tile "dia" (rtos dia 2 1)))  ;;; Dialog Menu Callback
  (if selections (set_tile "selections" selections))
(start_list "selections") (mapcar 'add_list names) (end_list) ) ;end of dfaults (initiate) (setq p1 (getpoint "\nSpecify starting point: ")) (command "circle" p1 dia) (command "-HATCH" "p" names "1" "" p1 "") (princ) ) (defun initiate () (setq dcl_id (load_dialog "ww.dcl")) (if (not (new_dialog "ww" dcl_id)) (exit) ) (DFAULTS) (action_tile "dia" "(setq dia (distof $value))") (action_tile "selections" "(setq selections $value)") (action_tile "accept" "(done_dialog)") (action_tile "cancel" "(exit)") (start_dialog) (unload_dialog dcl_id) (princ) )
Quick hack
(defun c:ww ()
(defun dfaults ()
(set_tile "selections" (if selections selections
(setq selections "0")))
(end_list)
) ;end of dfaults
(initiate)
(command "-HATCH" "p" (nth (atoi selections) names) "1" "" p1 "")
(princ)
(defun initiate ()
(exit)
(DFAULTS)
(start_dialog)
(princ)
HTH
pbejse
Message 2 of 4 (198 Views)
Re: list issues for a popup list
01-02-2014 07:42 PM in reply to: smaher12
Quick hack
(defun c:ww ()
(defun dfaults ()
  (end_list)
) ;end of dfaults
 (initiate)
 (princ)
(defun initiate ()
    (exit)
 (DFAULTS)
   (start_dialog)
     (princ)
HTH
smaher12
Message 3 of 4 (191 Views)
01-02-2014 08:05 PM in reply to: pbejse
Genius pbejse! I was playing around with the following but was not getting the correct results. You saved the day. Thanks!
(setq patt (atof (get_tile "selections")))
   (setq patt (fix patt))
      (setq patt (nth patt names))
pbejse
Message 4 of 4 (188 Views)
01-02-2014 08:09 PM in reply to: smaher12
You are welcome Smaher12, I can see your coding is progressing well, Keep it up.
pBe
