Valued Mentor
mdhutchinson
Message 1 of 8 (2,478 Views)
LIST command output to a file?
2478 Views, 7 Replies
12-15-2011 05:41 AM
The LIST command prints to the text screen.... when there is more than one screen, AutoCAD prompts: "Press ENTER to continue:"
I tried a cmdactive loop list this
(while (eq 1 (logand 1 (getvar "cmdactive")))
    (command "")
But it doesn't work in this case.
I thought there was a variable to control how many line of text goes to the textscreen but I can't seem to find it.
Any ideas how I can do this programmatically?
QAFLAGS 2
Valued Mentor
gjrcmb
Message 2 of 8 (2,464 Views)
Re: LIST command output to a file?
12-15-2011 09:50 AM in reply to: mdhutchinson
As far as how to control the length of the Text Screen, I copied the following from somewhere:
Command: (setenv "CmdHistLines" "1000")
In this example, I'm setting the history length to 1000 lines. The allowable range is between 25 lines and 2048 lines. If you try to set a value outside that range, it will default to the last used length. This new value gets saved to the current profile.
If you want to find out the current history length, you can type the following:  Command: (getenv "CmdHistLines")
"1000".  Note that "CmdHistLines" is case-sensitive and must be entered that way. Also, the length value must be included within quotes as shown.
Valued Mentor
mdhutchinson
Message 3 of 8 (2,458 Views)
12-15-2011 10:05 AM in reply to: gjrcmb
Thanks!
I was in hopes that this would suppress the "Press ENTER to continue:"
But alas it does not.
Might there be a way I can pass a script to the LIST that would issue the correct number of <enter> keys?   I wonder?
Active Member
StephenCollier
Message 4 of 8 (2,444 Views)
12-15-2011 03:40 PM in reply to: mdhutchinson
Hmmmm... the help says "You can use LIST to display and then copy the properties of selected objects to a text file."  I can't find any options to do that though.  I guess they mean you can manually do that.  I tried setting EXPERT to 1 as a long shot, but no go.  The only thing I can think of to suggest is to write the equivalent routine so you can totally control it... Might take a bit of time, but the code might be useful in future projects.
Valued Mentor
mdhutchinson
Message 5 of 8 (2,438 Views)
12-15-2011 06:27 PM in reply to: mdhutchinson
The option to get the text screen to a file is LOGFILEON... I ended up LISTing one object at a time. This then doesn't require the EnterKey from the user. Takes a bit longer, but it accomplished what I needed.
Woud still like to LIST all he objects together then get the text file... but I can't find the solution to get the Enter Key in Lisp to act in the midst of the LIST command output.
The info I need using the LIST comman is because I cannot find another way.  This is AutoCAD MEP and Autodesk took away all but the essential DXF data...
There might be a way to use a Script to do this EnterKey.. but I have not tried this yet.
pbejse
Message 6 of 8 (2,432 Views)
12-15-2011 08:14 PM in reply to: mdhutchinson
QAFLAGS 2
Valued Mentor
mdhutchinson
Message 7 of 8 (2,426 Views)
12-15-2011 09:04 PM in reply to: pbejse
Thank you!!!
I will test and come back to 'accept as an solution"
yes it works!!!
I didn't thing to look at undocumented commands.
... but why would they take this out?
pbejse
Message 8 of 8 (2,420 Views)
12-15-2011 09:28 PM in reply to: mdhutchinson
mdhutchinson wrote:
Thank you!!!
I will test and come back 'accept as an solution"
Glad I could help mdhutchinson
Cheers :smileyhappy:
