Hello I need a lisp to count or estimate blocks dynamic in a reference file, thanks
Hola, necesito un LISP para metrar bloques dinamicos, o cualquier tipo de bloques, y estimar distancias, tipo de bloque, cantidad, etc.
Do you have a specific block you're looking for? Is it all blocks, or all dynamic blocks?
Maybe one of these will help:
You can always use QSELECT and filter OBJECT TYPE for BLOCK REFERENCE whose NAME is equal to the block name you want.
Hola Ariel&Nico
Si subes el dwg donde quieres aplicar el lisp , puedes obtener mas ayuda
If you upload a sample DWG , you will get further help.
