Hi All:
Does anyone have a lisp routine that will.......
I have a block that is a square (a drainage structure), and I represent a pipe going into the square with 2 lines on the outside and a polyline with thickness in the center (the 2 outside lines are the diameter of the pipe)....anyway I usually use the trim command and select the square then use fence to trim the lines/poly to the square..then use break to break the poly a little more away from the square.....
Anyway I was wondering if anyone has a lisp that will do this....
Lynn
