Hi guys,
I am not sure what's preventing me from plotting in Autocad 2013, as I am able to run this routine through 2012 and it works. Has Autodesk do away with the command line plot? Thanks in advance! 🙂
(defun C:HALF ()
(COMMAND "PLOT" "Y" "" "ABC.pc3" "Oce18X24" "" "Landscape" "No" "Extents" "FIT" "CENTER" "Yes" "Halfsize.ctb" "yes" "yes" "No" "No" "N" "Y" "Y")
(PRINC)
Solved by hmsilva. Go to Solution.
haha. I will be gone the rest of the day, so have a wonderful weekend, guys. Much appreciate it! 🙂
@hmsilva wrote:
@kameron1967 wrote:
...can you test that routine and change the page setup to reflect your plotter information? I'd like to know if it will tell you whether both the plotter and page size is found. Thanks.
kameron,it will tell that whether both the plotter and page size is found...
From message #33
"Oce C+ 18x24 in (Landscape)"
from message #36
"Oce C+ 18x24in (Landscape)"
the name is not the same, tou have a space between 24 and in...
the names must be the correct one...
Henrique
You're right, Henrique. However, after putting a space and saving then reloading, I"m still getting the same error.
By the way, for the sake of adventuresome, I removed the "space (Landscape)" from the page size, no go there either. Well, I need to leave, so I will bid you gentlement farewell until next week. Thanks again! 🙂
@dmfrazier wrote:Thanks for the image, but that's not exactly what I meant either. I wanted to see the list of page sizes supported by the printer you are trying to print to. You can get to the list while editing a PC3 file.
Is this it then? Thanks.
kameron,
I'm getting confused...
It seems to me, that the image you're showing the paper size is from the system printer "Oce TDS320", not from the AutoCAD "Oce TDS320.pc3"
Henrique
You're absolutely right, Henrique!! See, I knew it was so close that I couldn't see. Yes, that was a system printer and once I removed the .pc3 from the plotter name, then it works. You're so awesome! Thanks, dude! 🙂
