Lisp to name current layout tab from attributes and then some
7 REPLIES 7
Message 1 of 8
swankster
1334 Views, 7 Replies
I am looking for a lisp that when executed, would rename the current layout tab to "DRAWINGNAME Rev REVISIONNUMBER" where DRAWINGNAME & REVISIONNUMBER are attributes pulled from the standard titleblock and Rev is just text.
Anybody seen anything that may work or have some partial code I may be able to combine to get what I'm looking for?
7 REPLIES 7
Message 2 of 8
hmsilva
in reply to: swankster
As a "demo",
change the "standard titleblock name" to the corret name
(defun c:demo ( / a aclyt attlst b hnd ss)
  (setq	aclyt (vla-get-activelayout
		(vla-get-activedocument (vlax-get-acad-object))
  (if (and (/= "Model" (vla-get-Name aclyt))
	   (setq ss (ssget "_X"
			   (list '(0 . "INSERT") )
				 '(2 . "standard titleblock name");; change it to the corret name
				 '(66 . 1)
				 (cons 410 (getvar 'CTAB))
    (progn
      (setq hnd	   (ssname ss 0)
	    obj	   (vlax-ename->vla-object hnd)
	    attlst (vlax-invoke obj 'GetAttributes)
      (foreach att attlst
	(cond ((= (vla-get-TagString att) "DRAWINGNAME")
	       (setq a (vla-get-TextString att))
	      ((= (vla-get-TagString att) "REVISIONNUMBER")
	       (setq b (vla-get-TextString att))
	(if (and a
		 b
	  (vla-put-name aclyt (strcat a " Rev " b))
  (princ)
hope that helps
Henrique
Message 3 of 8
swankster
in reply to: hmsilva
Thanks, getting an issue though:
too few arguments: (IF (AND (/= "Model" (vla-get-Name ACLYT)) (SETQ SS (SSGET "_X" (LIST (QUOTE (0 . "INSERT"))) (QUOTE (2 .
I tried messing with it but I am a total noob with lisp. I imagine the "model" thing is some kind of fail-safe if the command is used inside modelspace...
Message 4 of 8
hmsilva
Yes, it is.
Change only the '(2 . "standard titleblock name") to your titleblock name, and add
  (vl-load-com)
Or post your full code...
Henrique
Message 5 of 8
swankster
 Something still isn't right. I have updated the lisp with the correct info as shown.
				 '(2 . "dwg info and location for wind xref border");; change it to the corret name
				 '(66 . 1)
    (progn
      (foreach att attlst
	(cond ((= (vla-get-TagString att) "DWGNAME")
	      ((= (vla-get-TagString att) "REVNO.")
	(if (and a
		 b
  (princ)
 was getting that same error while loading the lisp but then started getting a syntax error.
Message 6 of 8
hmsilva
Sorry, my bad....
Had an extra bracket...
(defun c:demo (/ a aclyt attlst b hnd obj ss)
  (vl-load-com)
				 '(66 . 1)
    (progn
      (foreach att attlst
	      ((= (vla-get-TagString att) "REVNO.");; the TAG have a dot?
	(if (and a
		 b
  (princ)
EDIT: the above code has been fixed and should work as expected.
Henrique
Message 7 of 8
swankster
Very nice man, very nice. Thank you very much!
Message 8 of 8
hmsilva
You're welcome, swankster
Glad I could help
Henrique
”Boost
