I have blocks that were inserted in a drawing as part of program feature. The blocks have a LOCATION attribute (x y z) that indicates where the block is in reference to. The blocks have a different x y z values because of the programs attempt to place the block near the reference for clarity. To be more clear and to be visually able to see the reference point, I need to move these blocks from the insertion of the block relative to the LOCATION attribute values.
See attached Screen Shot 1.
I can do a move from the block insertion and chose a point offset from within the move command with the LOCATION attribute values (-3160.29,1372.43) which shows me that the block is associated with the center of red circle in Screen Shot 2a. What I would like is a custom move command that automates the base point insertion and point offset from the LOCATION attribute values.
I created a screen capture video showing the process I would like a lisp to automate if anyone could please help. See link below.
Thanks in advance for your time.
so you need code to do these tasks:
1) get location of an attribute from its tag (must have unique tags if multiple atts...)
2) get block insert location
3) move block that is already inserted
4) move atts by some vector, for block already inserted
Here is some code to help you get started. You will need to learn some lisp for this, and generally its not good to rely on customization you cannot maintain so that is expected IMO.
;(MAKE-LIST-OF-ATTRIBS-PTS (CAR (ENTSEL))) (defun MAKE-LIST-OF-ATTRIBS-PTS (EN / BLK ATT RET) (SETQ BLK (VLAX-ENAME->VLA-OBJECT EN)) (IF (= (VLA-GET-HASATTRIBUTES BLK) :VLAX-TRUE) (FOREACH ATT (VLAX-SAFEARRAY->LIST (VLAX-VARIANT-VALUE (VLA-GETATTRIBUTES BLK))) (SETQ RET (CONS (LIST (VLA-GET-TAGSTRING ATT) (VLA-GET-TEXTSTRING ATT) (GET-TXT-INSPT ATT)) RET)) ) ) (REVERSE RET) )
That is not beginner lisp either. All that VLA junk is "com" language, like VBA properties.
The tasks I identified above are not too hard, but they involve stuff relative to a given block which may have rotation and scale to deal with.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Thanks for the response. Here is a link to a screencast of what I would like a lisp to automate. It would be essentially a custom move command that reads the value of the attribute in the block selected as uses that as the _from base point. Hope this helps.
sorry, you will have to do some coding.
You can occasionally get full free service on things that have been done before so we are just paying forward, but this one is something you need to dig into.
Now that I said that, can you mention why you have not done that yet? Do you have any programming experience? Is it the time?
I'm always curious as LISP is fairly easy to pick up, and we can help a lot, but so many people don't its a shame.
