Hi all,
I modified this code again based on the chainage lisp posted here.
(defun c:polen (/ datum dist ld obj plen plength pt row rowh tox txtpos) (vl-load-com) (defun _text (p b o h c) (entmake (append '((0 . "TEXT") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (7 . "GHD Standard Arial") (8 . "C-CH_LABL") (100 . "AcDbText") ) (list (cons 10 (polar p (+ b PI) tox)) ) (list (cons 40 h)) (list (cons 1 (strcat "" (if (setq ld (nth (strlen (rtos c 2 0)) '(x "00" ""))) ld "") (rtos c 2 2)))) (list (cons 50 (+ b (/ PI 2) ))) '((41 . 1.0) (51 . 0.0) (71 . 0) (72 . 0) (11 0.0 0.0 0.0) (210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 0) ) ) ) ) ;;; Modified by pBe ;;; (defun _ang (en d pt) (+ (angle '(0.0 0.0 0.0) (vlax-curve-getfirstderiv en (vlax-curve-getparamatpoint en pt) ) ) (* pi 1.5) ) ) ;;; Modified by pBe ;;; (setq datum (getdist"\nEnter datum: ")) (setq height (getdist"\nEnter text height: ")) (setq row (getreal"\nChoose row: "));;;;select where to place text (setq tox (/ height 5));;offset from x axis (setq rowh (* (* (/ height 2) 10)-1)) (setq txtpos (+ (* rowh row)(/ height 2))) (setq dist 10) (setq offset 2);0 (setq to 2);0 (setq ss (ssget) count 0 ) (repeat (sslength ss) (setq ent (ssname ss count) obj (vlax-ename->vla-object ent) chainage dist plen (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj)) ) (setq p (vlax-curve-getstartpoint ent)) (setq p2 (vlax-curve-getendpoint ent)) (setq pt (list (car p) (+ (cadr p) txtpos )));;;;;;insertion point of text (setq plength ( + datum plen)) ;;; Additional option / re-arrange sequence ;;; ;;;;modified by mircea to get the elevation value of polyline (_text pt (_ang ent chainage p) to height plength) ;;; Start/Mid/End mode iI Length is less than or equal twice the value of dist variable ;;; (if (<= (setq ln (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent) ) ) (* 2 dist) ) (while (setq point1 (vlax-curve-getPointAtDist obj chainage)) (setq bearing (_ang ent (+ chainage dist) point1)) (setq chainage (+ chainage dist)) ) ) (setq count (1+ count)) ) (princ) )
the attached image (on the middle) is generated by this code by selecting the yellow lines.
can it be possible to achieve the image on the right side?
regards,
roldan
