Valued Contributor
bdsmls
Message 1 of 3 (324 Views)
LISP to create a two line MLEADER
324 Views, 2 Replies
07-18-2012 08:36 AM
I'm trying to write a lisp routine to create a two line MLEADER but i can only get one line of text. Creating the MLEADER manually from the command line i just have to hit enter after the first line of text to add a second line. How would i do this in a lisp routine?
Larry
Hallex
Message 2 of 3 (289 Views)
Re: LISP to create a two line MLEADER
07-22-2012 02:42 PM in reply to: bdsmls
Hi, Larry
Try this routine, set your text before:
(defun C:demo(/)
(setq txt "Blah\\PBlah\\PBlah");<-- set mleader text here
(princ "Type any character in the mtext window")
(command "_mleader" "_O" "_C" "_M" "_A" "_Y" "" "_X"  "_L" "_C" pause pause pause)
(setq ee (entget (setq en (entlast))))
(setq ee (subst (cons 304 txt)(assoc 304 ee) ee))
  (entmod ee)
  (entupd en)
  (command "_mleaderedit" "_L" "" "_A" (getpoint ) "")
  (princ)
~'J'~
Valued Contributor
bdsmls
Message 3 of 3 (273 Views)
07-23-2012 04:09 AM in reply to: Hallex
thanks for the response J
i just came up with a solution on friday thats works very nicely
(SETQ TELE(STRCAT TPFIX (RTOS TLV 4 2)))
(SETQ BELE(STRCAT BPFIX (RTOS BLV 4 2)))
(SETQ DUCEL(STRCAT TELE (CHR 10) BELE))
(COMMAND "MLEADER" BPT PAUSE DUCEL)
