Lisp to create a Polyline with arcs always with second point
2 REPLIES 2
gustavobernardi
723 Views, 2 Replies
Hi guys, a want to create a lisp to make electrical circuits using PLINES with arcs and specify the second point of each arc. Sequence: PLINE FIRST POINT (using a PAUSE) ARC (while SECOND POINT click a second point cilck a end point end of while) I tried the following: (defun c:PLARC() (command "._pline" pause "Arc" (while ("S" pause pause))) ) Not works... Thanks.
Tags (1)
2 REPLIES 2
Minimally tested:
(defun c:PLARC (/ pt)
  (command "._pline" pause "_arc")
  (while (setq pt (getpoint "\nSecond point [or <exit>]: "))
    (command "_s" pt pause)
  ); while
  (command ""); ends it with Enter/space
  (princ)
); defun
Kent Cooper, AIA
Work. Thanks.
”Boost
