Lisp to change Oblique Angle in Text and Mtext in BLOCK?
5 REPLIES 5
erickson123
2413 Views, 5 Replies
Hi Everyone,
Does anyone have a lisp to change the oblique angle (to 30 or whatever) inside a block that contains Text AND Mtext.  I've been coming up dry on my searches.  Thanks in advance!!
I've attached a block I would like to use it on....
5 REPLIES 5
hmsilva
in reply to: erickson123
Hi erickson123,
mtext is formated in the text string, not a propertie from the object.
Just a starting point.
(vl-load-com)
(defun c:demo (/ attlst hnd i lst obj str ss)
  (if (setq ss (ssget '((0 . "INSERT") (66 . 1))))
    (progn
      (repeat (setq i (sslength ss))
        (setq hnd    (ssname ss (setq i (1- i)))
              attlst nil
              obj    (vlax-ename->vla-object hnd)
              attlst (vlax-invoke obj 'GetAttributes)
        (foreach att attlst
          (if (= (vla-get-MTextAttributeContent att) "")
            (vla-put-ObliqueAngle att (* pi (/ 30.0 180.0)))
            (vla-put-TextString att (strcat "\\Q30.0;" (vla-get-TextString att)))
  (princ)
Henrique
erickson123
in reply to: hmsilva
RIGHT ON!
You are definitely TOP OF THE FOOD CHAIN!!!!
Thanks.
hmsilva
You're welcome, erickson123
Glad I could help
Henrique
How it works , I try to use it but no result
thanks
erickson123
I'm not a lisp writer, but this is how the lisp in the other message changed for our needs.  We use it to change text in topo maps from 'straight' to a 30deg slant.
(defun C:TX30 (/ ans text_entities mtext_entities)
  (vl-load-com)
;---------------------------------- TEXT & MTXEXT ---------------------------------------------
  (command "STYLE" "SIMPLEX S" "SIMPLEX" (* 0.00 (GETVAR "DIMSCALE")) "1.0" "30" "No" "No" "No")
  (setq text_entities
    (ssget "X"
      '((0 . "TEXT")(410 . "Model")
         (-4 . "<NOT")
           (-4 . "<OR")
             (8 . "*NA-SCALE*")(8 . "*STREET*")
           (-4 . "OR>")
         (-4 . "NOT>")
  (setq mtext_entities
    (ssget "X"
      '((0 . "MTEXT")(410 . "Model")
         (-4 . "<NOT")
           (-4 . "<OR")
           (-4 . "OR>")
         (-4 . "NOT>")
  (if text_entities
     (command "Optchprop" text_entities "" "t" "SIMPLEX S" "")
  );endif
  (if mtext_entities
    (command "Optchprop" mtext_entities "" "t" "SIMPLEX S" "")
  );endif
;--------------------------------- BLOCK ATTRIBUTES --------------------------------------------
(if (setq ss (ssget "X" '((0 . "INSERT") (66 . 1)(410 . "Model"))))
  (progn
   attlst nil
    (foreach att attlst
 (princ)
);defun
”Boost
