Visual LISP, AutoLISP and General Customization
Lisp to calculate multiple pline areas
4 REPLIES 4
7275 Views, 4 Replies
I am not a lisp programmer, so here is my question:
I have a drawing which contains about 100 "areas". These areas are closed
polylines. I would like to get a total area of all these polylines.
I have tried using AutoCAD 2002's AREA command, but I am only able to select
one item at a time, (AREA, Add, Object). This is fine for calculating a few
areas. It gives me a running total of each item that I select.
Using the LIST command works OK for a few items, but you still have to wade
through all the other information to get the area info for each item.
Is there a way to select crossing ALL the areas that I have, and have it
return a total? This would save a lot of time.
Dave
4 REPLIES 4
Give this a try:
;;;Ken Alexander
;;;Total area of lwpolylines
(defun C:tot_area (/ ss vlaobj cnt arealst tarea)
(vl-load-com)
(setq ss (ssget '((0 . "lwpolyline")))
cnt 0)
(if ss
(progn
(repeat (sslength ss)
(setq vlaobj
(vlax-ename->vla-object
(ssname ss cnt))
arealst (cons (vla-get-area vlaobj) arealst)
cnt (1+ cnt))
(setq tarea (apply '+ arealst))
(setq tarea 0)
(alert (strcat "\nTotal area is: " (rtos tarea 2 3)))
(princ)
"We can't solve problems by using the same kind
of thinking we used when we created them."
--Albert Einstein
Ken Alexander
Acad 2000
Windows XP Pro
"Dave Stelljes" wrote in message
news:E092C7AABA1DC31028A141764934C18F@in.WebX.maYIadrTaRb...
> Thanks,
> Dave
There are several of them out there...
Paul Turvill wrote one a while ago for R14 that works with A2k
http://www.turvill.com/t2/
under free stuff
called:
polyarea.lsp
> Thanks,
> Dave
Hi Dave
Can you do a little modification.
I want each object area seperate inside of every object.
Regards
Ismail
Kent1Cooper
A Search will turn up several ways to do that, for instance, here.
Kent Cooper, AIA
