Distinguished Contributor
JCprog
Message 1 of 8 (287 Views)
Lisp to align all blocks
287 Views, 7 Replies
04-29-2014 12:41 PM
Hello everyone:smileyhappy:
Situation:
If theres blocks A,B,C,D,E and they're all placed radomly (all have different xyz)
Thought:
Need a lisp that user picks first block (eg "Block A) as insertion point reference then routine ask which coordinate to follow (x, y, or z?) then select blocks to follow alignment. When user picks to follow block A's  x-coordinate.....block B,C,D,E should have same x-coordinate but maintain y & z unchanged.
This can be done manually but very tedious in a way. Please Help!
Thanks in advance:smileyhappy:
smaher12
Message 2 of 8 (270 Views)
Re: Lisp to align all blocks
04-29-2014 12:59 PM in reply to: JCprog
Here is one I have that will align text/blocks horizontaly. I'm sure it can easily be modified to meet your needs.
(defun c:blkalign ()
   (setq OS (getvar "OSMODE"))
   (setvar "OSMODE" 0)
	(princ "\nSelect blocks or text to align horizontaly evenly: ")
	(setq ss (ssget))
   (setq albl (entsel "\nSelect text or block to align with: "))
   (setq albl (car albl))
   (setq alpt (cdr (assoc 10 (entget albl))))
   (setq alpty (cadr alpt))
   (setq ctr 0)
     (while
       (setq ename (ssname ss ctr))
       (setq inpt (cdr (assoc 10 (entget ename))))
       (setq inptx (car inpt) )
       (setq inpty (cadr inpt))
       (setq newpt (list inptx alpty))
       (command "move" ename "" inpt newpt)
       (setq ctr (+ ctr 1))
   (setvar "OSMODE" OS)
dgorsman
Message 3 of 8 (264 Views)
04-29-2014 01:13 PM in reply to: JCprog
Manual way isn't very tedious.  Select the blocks (quick select if needed), plug the appropriate ordinate value into the Properties palette.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
JCprog
Message 4 of 8 (260 Views)
04-29-2014 01:21 PM in reply to: smaher12
Thanks for the reply smaher12,
It works horizontally, thanks for sharing! The routine just breaks when ucs is rotated but it works fine on world ucs. And it must not take out snap settings. Works more better than the align command (which is essentially no different from "move" :smileywink:
hmsilva
Message 5 of 8 (248 Views)
04-29-2014 01:40 PM in reply to: JCprog
JCprog wrote:
Situation:
Thought:
Hi JCprog,
as a start point...
(defun c:demo ( / ans ent i pt pt1 s ss)
  (if
    (and
      (not (prompt "\nSelect Block to follow coordinate: "))
      (setq s (ssget "_+.:E:S" '((0 . "INSERT"))))
      (not (initget "X Y Z"))
      (setq ans (getkword "\nEnter the coordinate to follow [X/Y/Z] <exit>:"))
     (if (and ans
	      (not (prompt "\nSelect Blocks to change coordinates: "))
	      (setq ss (ssget "_:L" '((0 . "INSERT"))))
       (progn
	 (setq pt (cdr (assoc 10 (entget (ssname s 0)))))
	 (repeat (setq i (sslength ss))
	   (setq ent (entget (ssname ss (setq i (1- i)))))
	   (setq pt1 (cdr (assoc 10 ent)))
	   (cond
	     ((= ans "X")
	      (entmod (subst (cons 10 (list (car pt) (cadr pt1) (caddr pt1)))
			     (assoc 10 ent)
			     ent
	     ((= ans "Y")
	      (entmod (subst (cons 10 (list (car pt1) (cadr pt) (caddr pt1)))
			     (assoc 10 ent)
			     ent
	     ((= ans "Z")
	      (entmod (subst (cons 10 (list (car pt1) (cadr pt1) (caddr pt)))
			     (assoc 10 ent)
			     ent
  (princ)
HTH
Henrique
JCprog
Message 6 of 8 (240 Views)
04-29-2014 01:57 PM in reply to: hmsilva
Thanks for the reply Henrique!
I dont think thats simply a "startpoint".....Thats technically a "nailed-down-finishpoint" to me....lol
Thanks a million!!!!!!!!!:smileyhappy: as always.....it works awesome!!!!!!!!
hmsilva
Message 7 of 8 (235 Views)
04-29-2014 01:59 PM in reply to: JCprog
You're welcome, JCprog
Glad I could help
Henrique
3wood
Message 8 of 8 (221 Views)
04-29-2014 02:45 PM in reply to: dgorsman
I always do this.
