Hello there,
i need a Lisp script to insert block that waits just the insertion point definition from user and always sets scale to 1 and rotation to 0
Can anybody help me in this?
Thanx
Gery
Solved by hmsilva. Go to Solution.
As a demo
(defun c:demo ( / dwg pt) (if (and (setq dwg (findfile "c:/MyPath/MyBlk.dwg")) (setq pt (getpoint "\nSpecify insertion point: ")) ) (command "_.insert" dwg "_S" 1 "_R" 0 "_NONE" pt) ) (princ) )
Hope that helps
Henrique
Thanx Henrique
It's about what i need.
i turned code to
(defun c:demo ( MyBlk / pt)
(if (setq pt (getpoint "\nSpecify insertion point: "))
(command "_.insert" MyBlk "_S" 1 "_R" 0 "_NONE" pt)
(princ)
Thats because i want to call it from command line typing the block name (wich is a dwg file located in my supported paths) :::
> demo BlkName
Something is wrong in above scripts , that doesn't work
You can't use arguments in a C:-defined command. Do it this way:
(defun demo ( MyBlk / pt) ; without the C:
Usage:
(demo "YourBlockName")
But I would do it a little differently, so that you can see it dragging into place as you go for the insertion point. The command will provide its own prompt, and the routine can end and just leave the command at that point:
(defun demo (MyBlk)
(command "_.insert" MyBlk "_S" 1 "_R" 0)
Usage:
(defun demo (MyBlk)
Are you sure.
We should not use arguments in a c: defined command, because it can be interpreted as a command line 'command', but is a function name and any other.
But you are correct the function named only demo is far more correct.
Cheers
Henrique
I wrote the following because i want the block to be exploded
(defun c:Demo () ;
(setq cmde (getvar "cmdecho"))
(setvar "cmdecho" 0)
(if (and (setq BlockName (getString "\nSpecify block name: "))
(setq InsertionPoint (getpoint "\nSpecify insertion point: "))
(command "_.insert" BlockName "_S" 1 "_R" 0 "_NONE" InsertionPoint)
(while (> (getvar 'cmdactive) 0)
(command pause)
(command "explode" "last")
(setvar "cmdecho" cmde)
(princ)
The above does't work why?
The following works instead but doesn't explode
(defun c:InsArchBlocks () ;
(princ)
While simply asking the question is easy,
it is not always the quickest way to a usable answer.
Before you ask, if you search some,
you may find a usable solution,
or find better words for the question.
IE, google: +insert +block autolisp
will find many examples.
What you probably want
is to use the 'getfiled function
to find a file to insert.
So then google: +insert +block +getfiled autolisp
(defun c:Demo () ;
(command pause)
(princ)
(princ)
To see where you made mistake in your (c:Demo) function, refer to the following link...
Recently, I've made the same mistake...
M.R.
@hmsilva wrote:
Are you sure.
From the AutoLisp Developer's Guide, under C:XXX functions:
To use functions as AutoCAD commands, be sure they adhere to the following rules:
Admittedly, that's from back in the 2004 edition. Oddly, Help in 2015 is milder about it:
Functions that are defined as commands should not accept arguments directly, instead input for a command should be obtained using one of the getXXX functions.
Why they use "should" rather than "must" as before, I couldn't say -- it's hard to imagine that the operation of (defun) has changed.
(princ)
[In the first one (not quoted above), It's not about finding the file, but the missing (progn) wrapper around the 'then' argument to the (if) function.]
But you can make that second one [quoteed above] work by Inserting the Block already exploded, with an asterisk prefix:
(command "_.insert" (strcat "*" BlockName) "_S" 1 "_R" 0 "_NONE" InsertionPoint)
(princ)
That does, however, preclude the option of dragging it visibly into place as I suggested before, because dynamic positioning like that doesn't work when inserting something pre-exploded.
@Kent1Cooper wrote:
@hmsilva wrote:
Are you sure.
Did you try to call the function with (c:demo "BlockName")?
Henrique
@Kent1Cooper wrote:
But you can make that second one [quoteed above] work by Inserting the Block already exploded, with an asterisk prefix:(defun c:InsArchBlocks () ;
(princ)
That was my first thought, but it throws an error, changing the prompt order, forcing the scale and rotation it errors, is expecting a point, and don't allow to change the prompt order...
Only with:
(defun demo (BlkName / pt)
(if
(command "_.-insert" (strcat "*" BlkName) "_NONE" pt "" "")
(princ)
Weird...
Henrique
Sorry , but my lisp knowledge is not enough and my english not so good
I need to build a command that uses a BlockName and and an Insertion point *just them) witch will be inserting by user , that inserts the block to the Insertion point and after that explodes the inserted block.
i do;t know what i have to write.
the followng inserts it BUT DOESN'T EXPLODE IT
(princ)
So, what else sould be written ?
Thanx
Gery
Gery try
(defun c:InsArchBlocks (/ BlockName cmde InsertionPoint) (setq cmde (getvar "cmdecho")) (setvar "cmdecho" 0) (if (and (setq BlockName (getString "\nSpecify block name: ")) (setq InsertionPoint (getpoint "\nSpecify insertion point: ")) ) (command "_.insert" (strcat "*" BlockName) "_NONE" InsertionPoint "" "") ) (setvar "cmdecho" cmde) (princ) ) ;; or (defun InsArchBlocks (BlockName / cmde InsertionPoint) (setq cmde (getvar "cmdecho")) (setvar "cmdecho" 0) (if (setq InsertionPoint (getpoint "\nSpecify insertion point: ")) (command "_.insert" (strcat "*" BlockName) "_NONE" InsertionPoint "" "") ) (setvar "cmdecho" cmde) (princ) ) ;; usage ;; (InsArchBlocks "YourBlockName")
Henrique
No, that doesn't work
The following works :
(defun fInsertOnInsP (BlkName / pt)
(if
(princ)
(defun c:InsArchBlocks1 ()
(if (setq BlockName (getString "\nSpecify block name: "))
(fInsertOnInsP BlockName )
(princ)
Because i need to set layer "1" (wich exists in my drawing) to Frzen state i wrote as
(if
(princ)
(command "_.layer" "F" "1" "")
(princ)
But that's not setting layer "1" too Frozen
What can i do ?
Gery,
the if function evaluates the test expression, if not nil will evaluate the next expression, if nil will evaluate the else expression...
;; your code (if (setq BlockName (getString "\nSpecify block name: "));; test exp (fInsertOnInsP BlockName );; if not nil exp (command "_.layer" "F" "1" "");; if nil exp ) ;; change to (if (setq BlockName (getString "\nSpecify block name: "));; test exp (progn;; if not nil exp (fInsertOnInsP BlockName) (command "_.layer" "F" "1" "") );; if not nil );; no if nil exp
Henrique
@hmsilva wrote:
.... Did you try to call the function with (c:demo "BlockName")?
No, I hadn't -- I just believed what I cited from the AutoLISP Developer's Guide, a "fact" that I have also seen others cite around here, and which has always seemed to be "the way it is." But sure enough, a C:XXX comand definition can be done with arguments. It's interesting that there would be an outright untruth in the documentation like that. [But I can also imagine that there might be circumstances I haven't encountered in which it would cause trouble, which would be a reason for the prohibition, though I don't have any ideas as to what they might be.]
