Lisp routine
6 REPLIES 6
786 Views, 6 Replies
Lisp routine
I need to make a lisp routine to draw a mound (mound_2004.dwg), it is saved in 2004 dwg format. Red lines are lines you have and grey lines are lines lisp routine needs to draw.
I have writen some part of lisp (mound.lsp), but have stoped at place where I need to find points on outer line. I wonder if here are some lisp functions to do it ( like this functions: vlax-curve-getPointAtDist, vlax-curve-getClosestPointTo), or I need to make one. I was looking here for functions. But could not found any or could not understand how to use it.
6 REPLIES 6
devitg
You can use the vlax-curve-getFirstDeriv obj param
(vlax-curve-getFirstDeriv curve-obj param)
It give the tan as SIN/COS  at the point given by PARAM , it return a 3 value list , one is the SIN the other is COS
You have to deal with it , at last you can get the angle perpendicular to the curve at such point
Then you have to make a line , search for it´s intersection points with the outer poliline by IntersectWith
search for more instruction at the VLIDE HELP .
Get the distance between both points , and make the new line related with the wide at such point .
any chance of sharing the lisp file.
JohnB
Not completed yet.
Works, but not finished
(vl-load-com)
(setq GDISTANCE 5)
(setq GOSNAP_VAR 0)
(setq GLAYER 0)
(setq GLAYER_NEW "Slaitas")
(setq GORTHOMODE 0)
(defun da_ChangePropertes ( / )
	(setq GOSNAP_VAR (getvar "osmode"))
	(setq GLAYER (getvar "clayer"))
	(setq GORTHOMODE (getvar "orthomode"))
	(setvar "osmode" 0)
	(command "_layer" "m" GLAYER_NEW "")
	(setvar "orthomode" 0)
(defun da_ReturnPropertes ( / )
	(setvar "osmode" GOSNAP_VAR)
	(setvar "clayer" GLAYER)
	(setvar "orthomode" GORTHOMODE)
(defun da_FixCoordinates (coords base_pt / first pt0 pt1 pt2 temp_coords)
	(setq temp_coords (list))
	(while (/= coords nil)
		(setq pt0 (list (car coords) (cadr coords)))
		(setq coords (cdddr coords))
		(setq temp_coords (append temp_coords (list pt0)))
	(list temp_coords)
(defun da_GetPolylineData (/ polyline_name)
	(setq polyline_name (car (entsel)))
	(if (= (cdr (assoc 0 (entget polyline_name))) "LWPOLYLINE")
		(setq polyline_name polyline_name)
		(setq polyline_name "0")
(defun da_GetPolyline (msg error_msg / polyline)
	(setq polyline "0")
	(while (= polyline "0")
		(princ msg)
		(setq polyline (da_GetPolylineData))
		(if (= polyline "0")
			(princ error_msg)
			(vlax-ename->vla-object polyline)
(defun da_GetPointsOnPolyline (ent_name / segment return_data count coord temp_list)
	(setq coord (vlax-get ent_name 'Coordinates))
	(setq count 1)
	(setq segment 0)
	(setq return_data (list))
	(setq temp_list (list (angle (list (car coord) (cadr coord)) (list (caddr coord) (cadddr coord)))))
	(setq coord (cddr coord))
	(while (/= count nil)
		(setq segment (+ segment GDISTANCE))
		(setq count (vlax-curve-getPointAtDist ent_name segment))
		(if (/= count nil)
			(if (> (vlax-curve-getDistAtPoint ent_name (list (car coord) (cadr coord))) segment)
				(setq temp_list (append temp_list (list count)))
				(progn
					(setq return_data (append return_data (list temp_list)))
					(setq temp_list (list (angle (list (car coord) (cadr coord)) (list (caddr coord) (cadddr coord))) count))
			(princ)
(defun da_Intersect (basept angle_in polyline_name / line_name coords)
	(setq coords (list))
	(while (/= basept nil)
		(command "line" (car basept) (polar (car basept) (- angle_in 1.570796325) 1) "")
		(setq line_name (entlast))
		(command "extend" (vlax-vla-object->ename polyline_name) "" line_name "")
		(command "extend" (vlax-vla-object->ename polyline_name) "" (list line_name (car basept)) "")
		(setq coords (append coords (da_FixCoordinates
			(vlax-invoke polyline_name 'IntersectWith (vlax-ename->vla-object line_name) acExtendNone) (car basept))))
		(setq basept (cdr basept))
		(command "erase" line_name "")
	(setq coords coords)
(defun da_FindCoordinatesProc (point1 point2 ac / ab x3 y3)
	(setq ab (distance point1 point2))
	(setq x3 (/ (* (- (car point2) (car point1)) (* ab ac)) ab))
	(setq y3 (/ (* (- (cadr point2) (cadr point1)) (* ab ac)) ab))
	(list (+ (car point1) x3) (+ (cadr point1) y3))
(defun da_DrawLine (coords / line_coords pt1 pt2 faze)
	(setq faze 1)
		(setq line_coords (car coords))
		(setq pt1 (car line_coords))
		(setq pt2 (cadr line_coords))
		(setq coords (cdr coords))
		(if (= faze 1)
			(progn
				(command "line" (da_FindCoordinatesProc pt1 pt2 0.9) (da_FindCoordinatesProc pt1 pt2 0.1) "")
				(setq faze 2)
			(progn
				(command "line" (da_FindCoordinatesProc pt1 pt2 0.7) (da_FindCoordinatesProc pt1 pt2 0.3) "")
				(setq faze 1)
(defun C:mound ( / middle_line_name outer_line_name middle_line_coordinates outer_line_coordinates)
	(setq GLAYER_NEW "Pylimas")
	(da_ChangePropertes)
	(setq GDISTANCE (cond ((getint (strcat "\nEnter distance: <" (rtos GDISTANCE 2 0) ">: "))) (GDISTANCE)))
	(setq middle_line_name (da_GetPolyline "\nSelect middle line. " "\n Error: not polyline."))
	(setq outer_line_name (da_GetPolyline "\nSelect outer line. " "\n Error: not polyline."))
	(setq middle_line_coordinates (da_GetPointsOnPolyline middle_line_name))
	(setq outer_line_coordinates (list))
	(while (/= middle_line_coordinates nil)
		(setq outer_line_coordinates (append outer_line_coordinates (da_Intersect (cdar middle_line_coordinates) (caar middle_line_coordinates) outer_line_name)))
		(setq middle_line_coordinates (cdr middle_line_coordinates))
	(da_DrawLine outer_line_coordinates)
	(da_ReturnPropertes)
	(princ)
(prompt "\n Enter \"mound\" to start program.")
(princ)
diagodose2009
YOU PROGRAM IS THE BEST ALGORITHM & PROGRAM
JUST I CONVERT TO C+ADS
IF YOU NEED CONERT YOUR SOURCE INTO C++ARX  OR C# ,PLEASE SEND TO ME THE PRIVATE MESSAGE
AFTER I CONVERTED YOUR SOUCE INTO C+ADS,
  THEN I WILL  SEE THE  SOURCE BEATIFUL IN C#
[CODE]
HERE   IT IS YOUR  PROGRAME:Smiley Tongue
(defun da_ChangePropertes ( / rr)
/c2s: GOSNAP_VAR=getvar("osmode");  // HERE IT IS THE PROGRAMMING LANGUAGE" VIRTUAL C+LISP"
       GLAYER=getvar("clayer");              // AFTER THE COMPILATION  ->  RESULT 100% LISP
       GORTHOMODE=getvar("orthomode");
       setvar("osmode",0);
       command("_layer","m",GLAYER_NEW,"");
       setvar("orthomode",0);
rr)
(Defun da_DrawLine (coords / line_coords pt1 pt2 faze rr)
/c2s:
  faze=1;
   while(coords != nil)
    { line_coords=car(coords);
      pt1=car(line_coords);
      pt2=cadr(line_coords);
      coords=cdr(coords);
     if (faze == 1)
      {   command("line",da_findcoordinatesproc(pt1,pt2,0.9),da_findcoordinatesproc(pt1,pt2,0.1),"");
          faze=2;
       } ; else
      {  command("line",da_findcoordinatesproc(pt1,pt2,0.7),da_findcoordinatesproc(pt1,pt2,0.3),"");
         faze=1;
rr)
(defun da_FindCoordinatesProc (point1 point2 ac / ab x3 y3 rr)
/c2s: ab=distance(point1,point2);
       x3= ( ( (car(point2)-car(point1))* (ab*ac))/ab);
       y3= ( ( (cadr(point2)-cadr(point1))* (ab*ac))/ab);
       rr=lISt( (car(point1)+x3), (cadr(point1)+y3));
rr)
(defun da_FixCoordinates (coords base_pt / rr first pt0 pt1 pt2 temp_coords)
/c2s: temp_coords=lISt();
    { pt0=lISt(car(coords),cadr(coords));
      coords=cadddr(coords);
      temp_coords=append(temp_coords,lISt(pt0));
   rr=lISt(temp_coords);
rr)
(Defun da_GetPointsOnPolyline (ent_name / rr segment return_data count coord temp_list)
 /c2s:  count=1;
         segment=0;
         return_data=lISt();
         while(count != nil)
          { segment= (segment+GDISTANCE);
            count=vlax.curve_getpointatdist(ent_name,segment);
            if (count != nil)
                return_data=append(return_data,lISt(count));
              else   terpri();
       rr=return_data;
rr)
/c2s: polyline="0";
   while(_tcscmp(polyline,"0") ==0)
    { princ(msg);
      polyline=da_getpolylinedata();
      rr=(_tcscmp(polyline,"0") ==0)?princ(error_msg):
          vlax_ename2vla_object(polyline) ;
rr)
(Defun da_GetPolylineData (/ polyline_name)
/c2s: rr=car(entsel());
      if (cdr(assoc(0,entget(rr))) == "LWPOLYLINE")
            rr=rr ;
        else
            rr="0";
rr)
(Defun da_Intersect (basept angle_in polyline_name / line_name coords)
/c2s:  coords=lISt();
        while(basept != nil)
         {  command("line",car(basept),polar(car(basept), (angle_in-1.570796325),1),"");
            line_name=entlast();
            command("extend",vlax.vla_object->ename(polyline_name),"",line_name,"");
            command("extend",vlax.vla_object->ename(polyline_name),"",lISt(line_name,car(basept)),"");
            coords=append(coords,da_fixcoordinates(vlax.invoke(polyline_name, "$ 'IntersectWith",vlax.ename->vla_object(line_name),acExtendNone),car(basept)));
            basept=cdr(basept);
            command("erase",line_name,"");
         rr=coords;
rr)
(defun da_ReturnPropertes ( / rr)
/c2s: setvar("osmode",GOSNAP_VAR);
       setvar("clayer",GLAYER);
       setvar("orthomode",GORTHOMODE);
rr)
//ByA:  Shinigami_black
%fopen(_pathuser("inc\lspfn_startvar.h"));
 (setq GDISTANCE 5)
 (setq GOSNAP_VAR 0)
 (setq GLAYER 0)
 (setq GORTHOMODE 0)
%fclose();
(Defun pp_asdk_mound( / rr middle_line_name outer_line_name middle_line_coordinates outer_line_coordinates)
/c2s:  dfn_cmd_browser(2);
        GLAYER_NEW="Pylimas";
        da_changepropertes();
        GDISTANCE=cond(getint(strcat("\nEnter distance: <",rtos(GDISTANCE,2,0),">: ")),nil;gdistance);
        middle_line_name=da_getpolyline("\nSelect middle line. ","\n Error: not polyline.");
        outer_line_name=da_getpolyline("\nSelect outer line. ","\n Error: not polyline.");
        middle_line_coordinates=da_getpointsonpolyline(middle_line_name);
        outer_line_coordinates=lISt();
        while(middle_line_coordinates != nil)
         { outer_line_coordinates=append(outer_line_coordinates,da_intersect(cdar(middle_line_coordinates),caar(middle_line_coordinates),outer_line_name));
           middle_line_coordinates=cdr(middle_line_coordinates);
       da_drawline(outer_line_coordinates);
       da_returnpropertes();
       terpri();
       dfn_cmd_browser(3);
rr)
[/CODE]
in reply to: diagodose2009
Will it increse speend of program?
I programm becouse I want to have more experience in programing and I hate to do manual work, which requires a lot of time and produce little results.
”Boost
