Valued Contributor
jason.estas
Message 21 of 30 (589 Views)
Re: Example of a typical room
01-17-2013 01:22 PM in reply to: pbejse
G'day,
I myself was after this very same lisp routine. But since I am not the best lisp creator I engaged the very one and only Lee Mac to write a program for me at a cost.
I have attached the program which he created for me as a kind of pay it forward situation.
Please do not modify the code in anyway and always leave Lee Mac at the Top.
Please enjoy as I know this little Lisp routine has help myself and my organization greatly.
Jasaon
scot-65
Message 22 of 30 (582 Views)
01-17-2013 03:45 PM in reply to: mwhea
mwhea wrote:
...thought about wanting to add into it later on like ceiling tiles for instances where we cant just space our lights evenly but based on an actual grid tile setout point.
Mwhea,
Attached files is what I showed earlier.
Giving more thought to the commercial (suspended ceilings) as well as residential,
I have developed the interface some more... Have a WIP look:
The LSP side of the above dialog has not been straightened out yet...
Scot-65
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Introverts is proof that there is indeed intelligent life on this planet.
scot-65
Message 23 of 30 (553 Views)
01-21-2013 03:30 PM in reply to: scot-65
REVISED, REWORKED, and STABILIZED.
Hopefully I have covered everything regarding light placement types for both Commercial and Residential.
The following interface is stabilized, and the help facility is developed, but not finished.
This is a working interface, the executing program is missing... Have a look.
Scot-65
Scot-65
Active Contributor
mwhea
Message 24 of 30 (548 Views)
01-21-2013 04:45 PM in reply to: jason.estas
Scot65,
From looking at your previous posts, the program you have made seems pretty in depth and would be very useful for companies (maybe post it serpately so more people may see it?) though in australia we use metric system so the imperial (inches) and what not doesn't work so much for us as we would be doing calculations all the time before inserting.
Mark
scot-65
Message 25 of 30 (532 Views)
01-22-2013 03:30 PM in reply to: mwhea
mwhea,
My brief taste into light layout included the required lumens value at floor level
based on the fixture output at the height specified above said floor level.
With this in mind one calculates the spacing between the lights. Stop here.
The interface begins where the spacing of the lights is known, and the
program will determine total number of fixtures in the given area.
Simple enough? (apologies if I did not understand you...)
Regarding metric, the executable part of the interface is not developed.
The interface can be reworded without much trouble to say CM or Meters...
Since I do not know "standard" Metric sizing's, I will leave this converting
up to you.
And Yes, this routine will be developed for our office. Production will
kneel at my feet and kiss the back of my hand when I release this...
Maybe they can each in turn buy me lunch for the next 3 months?
Scot-65   :-)
Scot-65
Valued Contributor
jason.estas
Message 26 of 30 (516 Views)
01-23-2013 06:13 PM in reply to: mwhea
mwhea,
Did you not see the lisp routine in my previous post? I too am from Australia and that program for which my company paid to get developed works a treat.
Let me know if it is what you are after!
Jason
New Member
Lexusmax
Message 27 of 30 (171 Views)
04-21-2014 12:13 AM in reply to: Kent1Cooper
You sir are a genius
Is there any way to pick block directly on drawing instead to type the block name.
Could we choose the side of Rectangular instead we choose the corner of the Rectangular .
Please help me this master. I deeply need your help.
Please reply me via my email tltrung@secvn.com
Thank you very much.
Le Trung
Kent1Cooper
Message 28 of 30 (160 Views)
04-21-2014 05:42 AM in reply to: Lexusmax
Le Trung
Welcome to the Forums!
I assume you mean you want to select a Polyline rectangle along any side, since either choosing something like a Line or choosing two endpoints of a side would not provide enough information.  If it's a closed Polygon rectangle, this simple edit of the routine seems to work.
(defun C:arb (/ c1 c2 wid ht rows cols blk); = Lights in Rectangular [& orthogonal] Room
  (setq
    pl (car (entsel "\nSelect Polyline rectangle: "))
    c1 (cdr (assoc 10 (entget pl)))
    c2 (vlax-curve-getPointAtParam pl 2)
    wid (abs (- (car c1) (car c2)))
    ht (abs (- (cadr c1) (cadr c2)))
    rows (getint "\nNumber of rows (---): ")
    cols (getint "\nNumber of columns (|||): ")
    blk (cdr (assoc 2 (entget (car (entsel "\nSelect Block to Minsert: ")))))
  ); setq
  (command
    "_.minsert" blk
    (mapcar '+ ; insertion point
      (list (min (car c1) (car c2)) (min (cadr c1) (cadr c2))); lower left of room
      (list (/ wid cols 2) (/ ht rows 2)); fractions of width/height
    ); mapcar
    "" "" "" ; X, Y, rotation defaults -- edit if needed
    rows cols (/ ht rows) (/ wid cols); numbers and spacings
  ); command
  (princ)
); defun
But ideally, it should be more sophisticated.  It could be made to check whether you selected a Polyline rectangle and a Block, and it could use the usual error handling and other controls.  But see whether it does what you want.
Kent Cooper
New Member
Lexusmax
Message 29 of 30 (141 Views)
04-22-2014 08:16 PM in reply to: Kent1Cooper
Hi Kent1Cooper,
I am grateful for your response.
Now I attach the .lsp file and drawing showed the case.
The attached lisp is to determine effect area by choose 02 corners.
But I need to determine by select 04 edge (using object osnap) as attached
drawing.
Please adjust my lisp file and send back to me.
Le Trung
Kent1Cooper
Message 30 of 30 (130 Views)
04-23-2014 04:26 AM in reply to: Lexusmax
[nothing attached...]
Kent Cooper
