*Adams, Steve
Message 1 of 4 (848 Views)
Lisp routine that will add up the lengths of all lines, arcs and polylines in
848 Views, 3 Replies
10-15-2003 11:45 AM
Hello Everybody,
I need a lisp routine that will add up the lengths of all
lines, arcs and polylines in a given layer.
Any ideas?
Thanks, Steve (Win98, A2K)
*Repetto, Alex
Message 2 of 4 (848 Views)
Re: Lisp routine that will add up the lengths of all lines, arcs and polyline
10-15-2003 03:18 PM in reply to: *Adams, Steve
Steve,
Below the content of an earlier posting from Jaysen Long (Date: 21-09-1999,
Subject: Total length of selected lines)
Alex
LL sums the length of all objects on selected layers.
OBL sums the length of selected objects.
Both print the output to the command line giving the lengths for different
layers as well as a total.
(defun c:ll ( / ) (ll:smileysurprised:utput "X" "\nSelect objects on layers to total...")
(princ))
(defun c:smileysurprised:bl ( / ) (ll:smileysurprised:utput "P" "\nSelect objects to total...") (princ))
(defun ll:smileysurprised:utput (ll:sstype ll:smileytongue:rompt / ll:ss i ll:ename ll:elist ll:layer
ll:layerlist ll:totallength
ll:layerlength ll:arcdelta
ll:smileysurprised:bjlength ll:space)
(prompt "\nLayer Lengths by Jaysen D. Long\nCopyright \2511998-1999. All
Rights Reserved.")
(setq ll:layerlist nil)
(prompt ll:smileytongue:rompt)
(if (setq ll:ss (ssget '((0 .
"ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,REGION,SPLINE"))))
(progn
(repeat (setq i (sslength ll:ss))
(setq ll:elist (entget (ssname ll:ss (setq i (1- i)))))
(if (not (member (setq ll:layer (cdr (assoc 8 ll:elist)))
ll:layerlist))
(setq ll:layerlist (append ll:layerlist (list ll:layer)))
(setq ll:totallength 0.0)
(foreach x ll:layerlist
(setq ll:layerlength 0.0)
(command "._select" ll:ss "")
(setq ll:ss (ssget ll:sstype (list (cons 0
"ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,REGION,SPLINE") (cons 8 x))))
(setq ll:ename (ssname ll:ss (setq i (1- i))))
(setq ll:elist (entget ll:ename))
(cond
( (eq (cdr (assoc 0 ll:elist)) "ARC")
(if (> (cdr (assoc 50 ll:elist)) (cdr (assoc 51 ll:elist)))
(setq ll:arcdelta (+ (abs (- (cdr (assoc 50 ll:elist)) (*
2.0 pi))) (cdr (assoc 51 ll:elist))))
(setq ll:arcdelta (- (cdr (assoc 51 ll:elist)) (cdr (assoc
50 ll:elist))))
(setq ll:smileysurprised:bjlength (* (cdr (assoc 40 ll:elist)) ll:arcdelta))
( (eq (cdr (assoc 0 ll:elist)) "LINE")
(setq ll:smileysurprised:bjlength (distance (cdr (assoc 10 ll:elist)) (cdr
(assoc 11 ll:elist))))
( (wcmatch (cdr (assoc 0 ll:elist))
"*POLYLINE,CIRCLE,ELLIPSE,REGION,SPLINE")
(command "._area" "_obj" ll:ename)
(setq ll:smileysurprised:bjlength (getvar "perimeter"))
(setq ll:layerlength (+ ll:layerlength ll:smileysurprised:bjlength))
(setq ll:space "" ll:smileytongue:rompt (strcat x ": " (rtos ll:layerlength 2 2)
" LF"))
(prompt (strcat "\n" x ": " (repeat (- 52 (strlen ll:smileytongue:rompt)) (setq
ll:space (strcat ll:space " "))) (rtos ll:layerlength 2 2) " LF"))
(setq ll:totallength (+ ll:totallength ll:layerlength))
(setq ll:space "" ll:smileytongue:rompt (strcat "Total: " (rtos ll:totallength 2
2) " LF"))
(prompt (strcat "\nTotal: " (repeat (- 52 (strlen ll:smileytongue:rompt)) (setq
ll:space (strcat ll:space " "))) (rtos ll:totallength 2 2) " LF"))
Jaysen
New Member
cwk1975
Message 3 of 4 (848 Views)
10-16-2003 02:08 AM in reply to: *Adams, Steve
I did this one with the help of newsgroups, so, thanks everyone..
*Adams, Steve
Message 4 of 4 (848 Views)
Re:
10-16-2003 10:25 AM in reply to: *Adams, Steve
Thanks a lot! I appreciate it.
Steve
"Alex Repetto" wrote in message
news:C58F2DE457B9D03E14AB6C1537968A4D@in.WebX.maYIadrTaRb...
> Steve,
21-09-1999,
> Alex
> (princ))
> Rights Reserved.")
> (progn
> ll:layerlist))
> (cond
> 50 ll:elist))))
ll:arcdelta))
2)
> " LF"))
(setq
> 2) " LF"))
> Jaysen
