Visual LISP, AutoLISP and General Customization
lisp routine - select polyline and apply formula help
21 REPLIES 21
Message 1 of 22
mpa-la
1529 Views, 21 Replies
I know this is a really simple routine, if someone could help me out I'd be very appreciative.  Here is the formula I would like to use:
(166.24 / X squared) * area of selected polyline.  An example for clarity, if X is 12 and the area of the selected polyline was 100, it would be (166.24 / 144) * 100 = 115.
I would like to issue the command, enter the number for X, pick the polyline, and have the resultant whole number (no decimals) output on the command line.  I would like it to remember whatever X is (for that drawing session) until I change it so that I can enter past that question if I'm not changing it.
Thanks again if you can help!
21 REPLIES 21
Message 2 of 22
mid-awe
in reply to: mpa-la
Is this what you are looking for?
(DEFUN c:SP-n-AF (/ AREA CUROBJ TTL X)
(VL-LOAD-COM) (SETQ X (GETREAL "\nEnter a value for X: ") CUROBJ (VLAX-ENAME->VLA-OBJECT (CAR (ENTSEL))) AREA (VLA-GET-AREA CUROBJ) TTL (* (/ 166.24 (* X X)) AREA) ) (PRINC (strcat "\n\t=>> Total after formula applied: " (FIX ttl) " \n")) (PRINC) )
Message 3 of 22
mpa-la
in reply to: mid-awe
It works!  When it returns the value though, it says (on the command line) "Select object: ; error: bad argument type: stringp" and then the formula result.  Is that a quick fix?
Thanks so much, this will be a real time saver!  Allison
Message 4 of 22
hmsilva
Change
(FIX ttl)
to
(itoa(FIX ttl))
HTH
Henrique
Message 5 of 22
mid-awe
in reply to: mpa-la
I'm not sure about the "noisy" command output. Everything finishes quietly here, but I'm on AC2013. Either way it doesn't look like a problem so long as the output is correct.
I'm glad it works for you. 🙂
Message 6 of 22
mpa-la
That fixed it!  I'm in 2014, btw.  Thank you so much!  Allison
Message 7 of 22
in reply to: mpa-la
Here is the modified code that will remember the last value of X until you close the drawing.
  (VL-LOAD-COM)
  (IF (NOT *X)
    (SETQ *X 100)
  (PRINC "\nEnter a value for X or <")
  (PRINC *X)
  (SETQ X (GETREAL "> : "))
  (IF (NOT X)
    (SETQ X *X)
    (SETQ *X X)
  (SETQ	CUROBJ (VLAX-ENAME->VLA-OBJECT (CAR (ENTSEL)))
  (PRINC (strcat "\n\t=>> Total after formula applied: " (ITOA (FIX TTL)) " \n"))
  (PRINC)
Message 8 of 22
mpa-la
Bonus!  Thanks for that, I wasn't going to ask Smiley Wink
Message 9 of 22
mid-awe
You need to remove X from the localized variables for the "remember the last value of X until you close the drawing" to work.
Message 10 of 22
Hi mid-awe,
Thanks for your reponse.
Your code was very short and sweet.
I think, we don't need to remove X. Because, I have used another varibale as "*X". This "*X" will remember the last value of X.
Message 11 of 22
mid-awe
Right on. I missed that * in front of the X. My appologies, and thank you for the addition.
Message 12 of 22
Lee_Mac
in reply to: mpa-la
Here's another way to write it:
(defun c:af ( / a e x )
    (setq x (cond ((getreal (strcat "\nX-Value <" (rtos (cond(x)(100)) 2) ">: ")))(x)(100)))
    (if (setq e (car (entsel)))
        (if (vl-catch-all-error-p (setq a (vl-catch-all-apply 'vlax-curve-getarea (list e))))
            (princ "\nInvalid object.")
            (princ (strcat "\nResult: " (itoa (fix (* a (/ 166.24 x x))))))
    (princ)
(vl-load-com) (princ)
Message 13 of 22
mid-awe
in reply to: Lee_Mac
& then you go and
you just
says, Lee Mac.
"Were not worthy" 🙂 Thank you.
Message 14 of 22
Kent1Cooper
@Lee_Mac wrote:
... (itoa (fix (* a (/ 166.24 x x))))
If what you want [it isn't clear to me from the original question] is actually the result rounded to the nearest whole number [up or down], rather than stripped of any decimal component no matter how large [i.e. rounded down only as the above does], replace the above part with:
(rtos (* a (/ 166.24 x x)) 2 0)
Kent Cooper, AIA
Message 15 of 22
mpa-la
in reply to: Kent1Cooper
I did want it rounded, thanks for that clarification.
Message 16 of 22
Lee_Mac
& then you go and
you just
says, Lee Mac.
Smiley Very Happy You're too kind mid-awe -
Though, looking back over my code, there is a slight mistake: the variable 'x' should be global (and perhaps renamed to something more obscure).
Message 17 of 22
mid-awe
I've been studying your "Object Align" code. I see you used "oa|rot" & "oa|off", two globals. I thought it was good practice to wrap globals in **? Or, you are using an old trick for namespacing? ObjectAlign.rotation & ObjectAlign.offset?
I use javascript a lot and I do something simular with my globals.
$oa = {
       rot: value,
       off: value,
$oa.rot = value;
$oa.off = value;
if ($ao.rot === 'false') {
        $oa.rot = 0.0
if ($ao.off === 'false') {
        $oa.off = 0.0
 Or, it could be thought of as a local-global 😉 I refere to the unlikely event that you'd reuse the same global for two different things.
Message 18 of 22
mid-awe
in reply to: mpa-la
Allison, would you mark the thread, solved? Thank you.
Message 19 of 22
in reply to: mpa-la
Thank you Mail.
Hello mid-awe,
This solution belongs you. Hence, I give full credit to you.
Hi Lee_Mac,
Special Thanks to you.
You will always have another way of coding which is out of Box.
Message 20 of 22
mpa-la
Whoops - sorry mid awe, I used the one from aliensinearth becuase it remembered my initial x value.  I didn't notice that it wasn't you!  I'm gonna see if I can accept two as solutions.  Allison
”Boost
