Member
vfernando
Message 1 of 6 (350 Views)
Lisp routine no longer working in new versions of AutoCAD
350 Views, 5 Replies
10-05-2012 11:40 AM
We have used this Lisp routine (moveatt.lsp) in the past to update our title block when the revision sections get full.
There are only 8 revision lines attributed with our title block.
The routine would remove the oldest revision and then shift all remaining revisions down to open up line 8 for use.
I think it was around release 2009 that the routine stopped working for us.
I have attached the lisp routine and a sample of our border.
Can anyone figure out what is wrong with our lisp routine that it will not work in AutoCAD 2012?
Thanks for any help.
vfernando,
I exclude the timer function,
try the attached file.
Henrique
hmsilva
Message 2 of 6 (334 Views)
Re: Lisp routine no longer working in new versions of AutoCAD
10-05-2012 02:54 PM in reply to: vfernando
vfernando,
moveatt function works, perhaps the external function (timer) is the problem,
that I can't see, if you post it I'll take a look.
Henrique
Member
vfernando
Message 3 of 6 (330 Views)
10-05-2012 03:04 PM in reply to: hmsilva
Sorry Henrique but I do not know what the external function (timer) is.
Here is the error I get when I run the routine:
        "Select drawing Border :; error: no function definition: TIMER"
So It sounds like you are correct it has something to do with the "timer".
If you tell me how to get you that information I will post it.
Thanks.
hmsilva
Message 4 of 6 (327 Views)
10-05-2012 03:14 PM in reply to: vfernando
vfernando,
Henrique
Member
vfernando
Message 5 of 6 (325 Views)
10-05-2012 03:20 PM in reply to: hmsilva
Yes!!!!
Success!!
Thank you Henrique!
That will save us all a bunch of time.
hmsilva
Message 6 of 6 (314 Views)
10-05-2012 03:26 PM in reply to: vfernando
You're welcome.
Henrique
