Lisp required to replace part of mtext with out prompt
11 REPLIES 11
Message 1 of 12
anoopvarrghese009
816 Views, 11 Replies
Please advise a lisp  to replace part of mtext (with 3 lines) with out prompt. MTEXT shown below
DATE: 28.05.2012
TEL NO: 04   2541131131
FAX NO : 04  5451212312
TeL no only want to replace with other pre defined no.
Please help
anoop
11 REPLIES 11
Message 2 of 12
What is your way of selecting the text to change?  Will the user select it or do you want to change all such text objects in the drawing?  However you select the text, once you make a vla-object out of it, it is easy to change the text value via
(vla-put-TextString "DATE: 28.05.2012\nTEL NO: 04   2541131131\nFAX NO : 04  5451212312")
Message 3 of 12
Thanks for reply. I want change all text in drawing.
Message 4 of 12
hmsilva
in reply to: anoopvarrghese009
Perhaps something like this.
Change the xx xxxxxxxxxx to the new number.
(defun c:test (/ ENT ENTD I SS STR)
  (if (setq ss "_X"
	    (ssget '((0 . "MTEXT")))
    (repeat (setq i (sslength ss))
      (setq ent	(entget (ssname ss (setq i (1- i))))
	    str	(cdr (assoc 1 ent))
      (if (wcmatch str "*TEL NO: 04 2541131131*")
	(progn
	  (setq	str (vl-string-subst
		      "TEL NO: xx xxxxxxxxxx"
		      "TEL NO: 04 2541131131"
		      str
	  (setq ent (subst (cons 1 str) (assoc 1 ent) ent))
	  (entmod ent)
  (princ)
HTH
Henrique
Message 5 of 12
anoopvarrghese009
in reply to: hmsilva
Thank for you effort, but its not working, showing below message. Can u chek in my attached drawing
Command: test
Unknown command "TEST". Press F1 for help.
Command: 'VLIDE too few arguments in SETQ: (SETQ SS "_X" (SSGET (QUOTE ((0 .
"MTEXT")))))
Command:
Command: test
Message 6 of 12
Try
(defun c:test21 ( / ent vlobj textString )
  (setq ent (entnext))
  (while ent
    (setq vlobj (vlax-ename->vla-object ent))
    (if (= "AcDbMText" (vla-get-objectname vlobj))
      (progn
 (setq textString (vla-get-textstring vlobj))
 (terpri)(princ textString)(terpri)
 (if (and (vl-string-search "DATE" textString) (vl-string-search "TEL NO" textString) (vl-string-search "FAX NO" textString))
   (vla-put-textString vlobj "DATE:xxxx\nTEL NO:xxxxxx\nFAX NOxxxxxxx")
    (setq ent (entnext ent))
  (princ)
Message 7 of 12
thank you its working, font is getting changed can you add that also?
anoop
Message 8 of 12
The font type doesn't change on mine.  If you mean the actual text, change the string I put in the LISP to whatever string you would like.  Otherwise, repost you document after the font has changed so I can take a look.
Message 9 of 12
hmsilva
Sorry, my code have a typo...
Try this one
  (if (setq ss (ssget "_X" '((0 . "MTEXT"))))
      (if (wcmatch str "*2541131131*")
	(progn
		      "xxxxxxxxxx"
		      "2541131131"
		      str
	  (entmod ent)
  (princ)
HTH
Henrique
Message 10 of 12
anoopvarrghese009
Thank you
Message 11 of 12
thank you
Message 12 of 12
hmsilva
You're welcome!
Glad I could help
Henrique
”Boost
