LISP reads DB that contains Points
5 REPLIES 5
240 Views, 5 Replies
Can LISP reads a DB that contains points and bearing/distance and then create a polygon coming from those points/bearing and distances? because i want ot create a polygon whos points comesfrom a DB. thanks.
5 REPLIES 5
devitg
Hi Freddy , did you have a db sample ?.
If so , please uploadit , and a dwg base where you want to use it.
The short answer is yes it can. But it would be easier to export the points
to a text file and read that.
wrote in message news:5049723@discussion.autodesk.com...
Im using Progress Database. Actually my project is land parcel system where it will automatically draw a parcel using points (e.g 23D19' 45 m) that are stored in the Progress DB. and im using lsp to for that. do you have a sample similar program ? thanks.
actually that's what im thinking but my problem is what if there are additional land title? parcels usually subdivide sometimes merges so there are continuos updates.so it would be great if it will connect directly to the database. thanks.
Do a search for ADOlisp or go to http://www.fleming-group.com/
you can query a database using sql statements and return the values in a list format.. cool stuff
”Boost
