Lisp Program to change layers (Small problem)
2 REPLIES 2
canuck7783
245 Views, 2 Replies
I had the lisp below running on autocad 2002 with no problems.  I put it on a machine that is running Autocad 2014 and I have one small problem.  When I was on autocad 2002 I could select an object line and then run my lisp program by clicking "WW" and it would change to the correct layer "PART".  On the autocad 2014 machine, it won't let me do it.  I have to run the lisp program first (clicking "WW" first), it then asks me to select the object layer you want to change and then it changes to the correct layer.  I already messed around with the "Pickfirst" option and that isn't it.  Is there something wrong with my coding that I'm not seeing.  Maybe there is a better way to write the program to do what I want.  I am up for suggestions.
Thank you
Lisp Program Below
; ---------------------------PART LISP--------------------------
;       CHANGES A SELECTED OBJECTS LAYER TO LAYER "PART"
(Defun C:WW (/ SS CNT LAY)
(setvar "cmdecho" 0)
(if (not (tblsearch "LAYER" "object"))
(command "Layer" "N" "PART" "C" "red" "PART" "LT" "continuous" "PART" "" ""))
  (if (not (setq SS (ssget "i")))
    (progn
      (prompt "\nSelect objects to be CHANGED to layer PART: ")
      (setq SS (ssget))
  (if SS
      (command "_.change" SS "" "_p" "_la" "PART" "")
      (if (= (sslength SS) 1)
        (prompt (strcat "\nOne object changed to layer "PART"))
        (prompt (strcat "\n" (itoa (sslength SS)) "objects changed to layer "PART")
(setvar "cmdecho" 1)
  (princ)
2 REPLIES 2
Ajilal.Vijayan
in reply to: canuck7783
The below changes(in Bold) to the code works on 2014.
(Defun C:WW (/ SS CNT LAY slctn)
(setq slctn nil);flag to set the active selection
(if (not (tblsearch "LAYER" "PART"))
    (progn
	(print "No Selection")
      (setq SS (ssget))
	(setq slctn T);Trun the flag ON as there is a PICKFIRST selection found
  (if slctn ;if PICKFIRST selection found
  (progn
      (command "_.change" "_p" "_la" "PART" "")
        (prompt (strcat "\nOne object changed to layer PART"))
        (prompt (strcat "\n" (itoa (sslength SS)) " objects changed to layer PART"))
	);progn
	(command "_.change" SS "" "_p" "_la" "PART" "");no PICKFIRST selection
  (princ)
canuck7783
in reply to: Ajilal.Vijayan
Thank you, that works perfectly!!!
”Boost
