Active Member
LightingDesignAlliance
Message 1 of 6 (381 Views)
Lisp not working with 64bit stations
381 Views, 5 Replies
06-23-2011 03:05 PM
I have a lisp that is pulling annotations from one block and assigning them as fields in another block, seems to work fine on 32bit stations but returns #### in the fields for 64bit stations.
Thanks in advance
Add the following codes by Gile to your codes to get the ObjectID .
(defun gc:GetObjectIdString ( obj )
(or *util* (setq *util* (vla-get-Utility (vla-get-ActiveDocument (vlax-get-acad-object)))))
(if (vlax-method-applicable-p *util* 'GetObjectIdString)
(vla-GetObjectIdString *util* obj :vlax-false)
(itoa (vla-get-ObjectId obj))
The Code you posted has (rtos objID 2 0).  Is the object ID ever a real?  I think it's integer..
Try switching:
(setq
      obj   (vlax-ename->vla-object ent)
      objID (vla-get-objectid obj)
      str (strcat "%<\\AcObjProp Object(%<\\_ObjId "(rtos objID 2 0)">%).TextString \\f \"%tc1\">%")
in your code to:
(setq
      str (strcat "%<\\AcObjProp Object(%<\\_ObjId "(itoa objID)">%).TextString \\f \"%tc1\">%")
I don't have a 64bit sys to test on..
Next step would be to make the field manually on the 64 bit system and then check the string to make sure what you have in your lisp matches it I would think.
Then you may have to use a different value for 'str depending on if the system is 32 or 64 bit (if possible)
Distinguished Mentor
_Tharwat
Message 2 of 6 (376 Views)
Re: Lisp not working with 64bit stations
06-23-2011 03:43 PM in reply to: LightingDesignAlliance
Without even taking a look the problem is with the object id .
Tharwat
____________________________________________________
Get learn and learn and practice , to become experienced guy .
Active Member
Message 3 of 6 (368 Views)
06-23-2011 09:07 PM in reply to: LightingDesignAlliance
Can you tell ne how to fix, I am a lisp novice.
_Tharwat
Message 4 of 6 (358 Views)
06-24-2011 12:32 AM in reply to: LightingDesignAlliance
Valued Mentor
Shneuph
Message 5 of 6 (340 Views)
06-24-2011 10:00 AM in reply to: LightingDesignAlliance
Try switching:
(setq
in your code to:
(setq
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Active Member
Message 6 of 6 (326 Views)
06-24-2011 10:37 AM in reply to: Shneuph
I added both to the lisp and I am now getting the correct data returned on my fields. Thank you both so much for the help. -Jason
