can a routine modify the standard table from extracted data? i'd like to take y coordinates, such as 100'- 6", and display it as N. 100'-6 or S. 100'-6" for a negative value. the same process for x coordinates and display them as E. "value" or "W. "value". i don't anything about writing code, so i appreciate anyone willing to help me with this. thanks
You might need to clarify with an image on what you trying to accomplish. Meanwhile the following will allow you to pick points and display N. or S. for a negative value and same for E. or W. Don’t know, may or may not help….
(defun c:test (/ pt x y x1 y1)
(setq pt (getpoint "\nSpecify point: "))
(setq x (rtos (car pt)))
(setq y (rtos (cadr pt)))
(if (> (car pt) 0)
(setq xpos "E. ")
(if (< (car pt) 0)
(setq xpos "W. ")
(if (> (cadr pt) 0)
(setq ypos "N. ")
(if (< (cadr pt) 0)
(setq ypos "S. ")
(setq x1 (abs (atof x)))
(setq y1 (abs (atof y)))
(command "_.text" "m" pt "" "" (strcat ypos (rtos y1 4 1) " " xpos (rtos x1 4 1)))
(princ)
