Visual LISP, AutoLISP and General Customization
Lisp Modification
3 REPLIES 3
gbarfield
500 Views, 3 Replies
Lisp Modification
We have a lisp routine that places a vertical line in front of text and mtext.  I want to start using the multi-leader command instead of a customized leader.  Can anyone take a look at our routine and offer suggestions on modifying it so it can work with multi-leaders?  The lsp file is attached.
3 REPLIES 3
andrew.nao
in reply to: gbarfield
replace
(COMMAND "LINE" ....
with
(COMMAND "MLEADER".... or whatever you want to use in place of "line"
gbarfield
in reply to: andrew.nao
Should anything be done to the line near the beginning that is listed below?  Should anything about multi-leader be put in there?
(SETQ ITEMS (SSGET '((0 . "TEXT,MTEXT")))); revised to only get text
gbarfield
Maybe I didn't make myself clear with my first question.  If I make the change that you suggested, it'll draw a multileader in front of the text and not a line.  I still want a line in front of text, but I want to be able to select multi-leader text as well as text and mtext.
”Boost
