Visual LISP, AutoLISP and General Customization
lisp modification help (automatic attribute selection)
3 REPLIES 3
vahe.holtian
344 Views, 3 Replies
hey
i have a very useful lisp routine that helps me increment the numbers in the selected tag.
i just want to make it choose the tag ("BAR_MARK") automatically..
(meaning that clicking on the block wil do the work and its not necessary to click on the tag)
can anyone help?
3 REPLIES 3
pbejse
in reply to: vahe.holtian
quick mode on the code
here's a snippet, [refer to the attached file]
(while (and (/= fin 1) (not (or (= id "Pause") (= id "TEXT") (= id "MTEXT") Tag_found )))
((/= obj nil) (setq objid (entget (car obj)))
					 (setq id (cdr (assoc 0 objid)))
					 (setq Tag_found
					 (if (and (= id "INSERT")
						  (= (cdr (assoc 66 objid)) 1)
						  (setq obj (vl-remove-if-not
							  '(lambda (j)
							     (eq (vla-get-tagstring j) "BAR_MARK")
							  (vlax-invoke (setq vl_obj (vlax-ename->vla-object (car obj))) 'Getattributes)
						  (setq obj (list (vlax-vla-object->ename (car obj)))))
					   	  T nil))
vahe.holtian
in reply to: pbejse
thank you!! Smiley Very Happy
pbejse
You are welcome vahe.holtian.keep on coding.
Cheers
”Boost
