Visual LISP, AutoLISP and General Customization
LISP makes SFSP Uppercase
2 REPLIES 2
Jeffery.B
288 Views, 2 Replies
Hey guys,
I'm using a lisp routine to remove certain file paths from the SFSP but after running the lisp, the remaining SFSPs are all uppercase.  Is there a way to get it to just leave the paths in lowercase? Any help is greatly appreciated!
(defun DelPath (PathtoDelete / lst tmp)
(setq PathtoDelete (strcase PathtoDelete))
(setq lst (mapcar 'strcase (strParse (getenv "ACAD") ";")))
(if (member PathtoDelete lst)
(progn
(setq lst (vl-remove (strcase PathToDelete) lst))
(setq tmp "")
(foreach folder lst
(setq tmp (strcat tmp folder ";"))
(setenv "ACAD" tmp)
(princ)
2 REPLIES 2
paullimapa
in reply to: Jeffery.B
If you want it all in lowercase, change this line of the code from:
To
(setq tmp (strcat tmp (strcase folder T) ";"))
Area Object Link | Dwg Setup | Feet-Inch Calculator
Exchange App Store
Paul Li
IT Specialist
@The Office
Jeffery.B
in reply to: paullimapa
Thanks Paul, it works great!
”Boost
