Active Contributor
haynesc87
Message 1 of 4 (243 Views)
LISP Help please
243 Views, 3 Replies
08-09-2012 10:38 AM
Hi all
I would like a LISP to do the equivilent of the following :
qselect ....
Object : Space
Properties: Layer
Operatior: Wildcard
Value: *Mega*
Send to Back
Could anyone help me with the LISp for this thanks
Chris
Distinguished Contributor
tom_brabant
Message 2 of 4 (234 Views)
Re: LISP Help please
08-09-2012 01:29 PM in reply to: haynesc87
Here might be a start. This would send anything on a layer beginning with "Mega" to the back.
(defun c:MegaStarToBack ()
(setq ss (ssget "x"
(list; begin filter
(cons 8 "Mega*")
);end filter
(command "draworder" ss "" "Back")
Active Contributor
haynesc87
Message 3 of 4 (188 Views)
08-13-2012 03:21 AM in reply to: tom_brabant
Hi thanks ...
what do the ")" ? mean? ...
if i open notepad what exactly do i need to type for the script to work ?
iv wrote a script before bujt iv never seen them look like this before ... normally mine look like :
VISRETAIN 0
-XREF R *
VISRETAIN 1
QSAVE
CLOSE
For example
tom_brabant
Message 4 of 4 (169 Views)
08-13-2012 07:47 AM in reply to: haynesc87
Everything from the "(defun" to the final ")" constitute an autolisp function definition. This particular function definition happens to add a new command to an autocad drawing session. I have reposted the contents at bottom, and shortened the new command's name to "tb" for convenience.
One of several ways to make it work is to:
1. Copy the contents and paste them into notepad and save the text file with a ".lsp" extension.
2. Then, in autocad, use the "appload" command to browse to the newly created file and load it into a drawing session.
3. Invoke the command by typing "tb" at the command line.
I might mention that appload also contains a "startup suite" so that frequently used files can be loaded into any drawing session automatically.
(defun c:tb ()
(setq ss (ssget "x"
(list; begin filter
(cons 8 "Mega*")
);end filter
