Visual LISP, AutoLISP and General Customization
LISP Help Needed For SaveAs
7 REPLIES 7
Message 1 of 8
elijahvoigt
441 Views, 7 Replies
Hello I have written a LISP routine to help with file preparation for this certain type of software. I have to go through several commands to clean the file, then I need to export it to a ASCII R12 DXF(by selecting all objects upon save). Long story of why this works, but it does. The issue is when I try to "saveas" in my routine I don't see an exported DXF on my hard drive, but if I do it manually without the LISP it asks me if i want to overwrite the file as if it is on my hard drive. Any thoughts or advice on how I can change my LISP, or any other thoughts that might be causing this problem? Thanks in advance. File is attached.
Civil 3D 2014
i7-3930K Overclocked
32 GB Ram
Windows 7 Professional
7 REPLIES 7
Message 2 of 8
olbapxpablo
in reply to: elijahvoigt
before taking any action have you check the folder option?
on folder press "f10" click "tools" "folder option" "view" tab then click show hidden files
Message 3 of 8
hmsilva
'File is attached.'
File???
Henrique
Message 4 of 8
elijahvoigt
in reply to: hmsilva
Civil 3D 2014
32 GB Ram
Message 5 of 8
elijahvoigt
in reply to: olbapxpablo
I did double check that, yes show all files is on.
Civil 3D 2014
32 GB Ram
Message 6 of 8
hmsilva
Untested...
(defun c:demo ()
  (command "plan" "world")
  (command "-layer" "on" "*" "")
  (command "-layer" "thaw" "*" "")
  (command "chprop" "all" "" "layer" "0" "")
  (command "-layer" "set" "0" "")
  (command "-purge" "all" "*" "no")
  (command "filedia" "0")
  (if (findfile "D:\\rename.dxf")
    (command "saveas" "dxf" "v" "r12" "o" "all" "" "" "D:\\rename.dxf" "Y")
    (command "saveas" "dxf" "v" "r12" "o" "all" "" "" "D:\\rename.dxf")
  (command "filedia" "1")
  (princ)
Henrique
Message 7 of 8
elijahvoigt
Henrique that worked great! Thank You!
Civil 3D 2014
32 GB Ram
Message 8 of 8
hmsilva
You're welcome!
Glad I could help
Henrique
”Boost
