I am writing a LISP that takes a folder the user selects that contains 10 drawings in it, and takes those drawings and inserts them into their corresponding drawing that is on a network drive. I had the LISP working perfectly if the user was able to select the network folder that contains the empty drawing and also selects the folder that contains the 10 drawings. but now the problem is that user is not going to be able to select the network folder because of other issues. The problem I am having is that there are several network folders that may contain the drawings they are working on. I wrote a function that goes into the network drive and creates a directory list of every .dwg in the network drive. but now I need a function to be able to go into that list and set a variable to just that directory that contains that same .dwg name.
where it says XXXXX is where I am getting lost
(defun c:insertdesign (/ DirPath1 DirPath2 DwgA DwgB DwgList1 DwgList2 LstB OpFil ScrFil) (if (and (setq DirPath1 (SubFolderSearch "T:\\projects\\" ".dwg")) (setq DirPath2 (BrowseForFolder "Select the folder containing the design drawings to INSERT.")) (/= DirPath1 DirPath2) ) (progn (setq DwgList1 (DirPath1) DwgList2 (vl-directory-files DirPath2 "*.dwg" 1) ScrFil "C:\\temp\\Temp.scr" OpFil (open ScrFil "W") ) (foreach Dwg DwgList2 (if (setq LstB (member Dwg DwgList1)) (progn (setq DwgA (XXXXXXXXXXXXXXXXX) DwgB (strcat DirPath2 (car LstB)) ) (write-line (strcat "_.open " (chr 34) DwgA (chr 34)) OpFil) (write-line "model" OpFil) (write-line (strcat "_.-insert " (chr 34) (chr 42) DwgB (chr 34) " 0,0,0 1 0") OpFil) (write-line "zoom extents" OpFil) (write-line "layon" OpFil) (write-line (strcat "ssx layer " (chr 34) "level 34 " (chr 40) "construction" (chr 41) (chr 34) " ") OpFil) (write-line "erase previous " OpFil) (write-line "ssx entity ellipse " OpFil) (write-line "erase previous " OpFil) (write-line "zoom extents" OpFil) (write-line "flatten all no" OpFil) (write-line "ssx color 2 " OpFil) (write-line "erase previous " OpFil) (write-line "ssx color 3 " OpFil) (write-line "erase previous " OpFil) (write-line "ssx color 7 " OpFil) (write-line "erase previous " OpFil) (write-line "ssx color 30 " OpFil) (write-line "erase previous " OpFil) (write-line "ssx entity 3dface " OpFil) (write-line "erase previous " OpFil) (write-line "ssx entity solid " OpFil) (write-line "erase previous " OpFil) (write-line "ssx entity text " OpFil) (write-line "erase previous " OpFil) (write-line "ssx entity Mtext " OpFil) (write-line "erase previous " OpFil) (write-line "tilemode 0" OpFil) (write-line "-layer new viewport plot no viewport " OpFil) (write-line "ssx entity viewport " OpFil) (write-line "change previous p la viewport " OpFil) (write-line "-plot y layout1" OpFil) (write-line "PRINTER" OpFil);;;;CHANGE TO YOUR DEFAULT PRINTER (write-line "letter" OpFil) (write-line "inches landscape no layout fit" OpFil) (write-line "0.07,0.14" OpFil) (write-line "yes monochrome.ctb" OpFil) (write-line "yes no no no no yes no" OpFil) (write-line "-insert overlay" OpFil) (write-line "5.7640,0.0133,0.00 1 1 0" OpFil) (write-line "-bedit tb_text" OpFil) (write-line "change -1.53,0.53,0 -1.55,0.51,0 ROMAND 0.115 0 title3 enter title3" OpFil) (write-line "TITLE3" OpFil) (write-line "bsave bclose" OpFil) (write-line "attsync name tb_text" OpFil) (write-line "updatefield all " OpFil) (write-line "mspace zoom extents pspace" OpFil) (write-line "tbupdate" OpFil) (write-line "qsave" OpFil) (write-line "close" OpFil) );; progn );; if );; foreach (close OpFil) (command "_.script" ScrFil) );; progn );; if (princ) );; inserts
Solved by hmsilva. Go to Solution.
(defun SubFolderSearch (Path FileExt / tempPath FileList) (setq Path (if (= (substr Path (strlen Path)) "\\") Path (strcat Path "\\") );;if ) (foreach file (vl-directory-files Path) (setq tempPath (strcat Path file)) (if (not (or (= file ".") (= file "..") ) ) (if (vl-file-directory-p tempPath) (setq FileList (append FileList (SubFolderSearch tempPath FileExt))) (if (= (strcase FileExt) (strcase (vl-filename-extension tempPath))) (setq FileList (cons tempPath FileList)) ) ) ) ) FileList )
Maybe something like this
(foreach Dwg DwgList2 (if (and (setq DwgC (strcat (vl-filename-base Dwg) ".dwg")) (setq LstB (member DwgC DwgList1)) );; and (progn (setq DwgA Dwg DwgB (strcat DirPath2 (car LstB)) )
HTH
Henrique
Sorry Justin, my bad...
I don't have AutoCAD with me, so is untested...
(progn (foreach x DirPath1 (setq DwgNames1 (cons (strcat (vl-filename-base x) ".dwg") DwgNames1)) ) (setq DwgList1 DirPath1 DwgList2 (vl-directory-files DirPath2 "*.dwg" 1) DwgNames1 (reverse DwgNames1) ScrFil "C:\\temp\\Temp.scr" OpFil (open ScrFil "W") ) (foreach Dwg DwgList2 (if (setq pos (vl-position Dwg DwgNames1)) (progn (setq DwgA (nth pos DwgList1) DwgB (strcat DirPath2 Dwg) pos nil )
Henrique
Henrique you once again provail!! just out of curiosity, why do you reverse DwgNames1?
also as a side question, do you know a function or script command to get default printer name?
The DwgNames1 list is created in reverse order from the DwgList1 list, to ensure the same order ( to use the nth function)I need to reverse the list.
The 'default printer name' is the Windows or the Document default printer?
Henrique
I am writing this LISP to be used by several people and they are in different buildings using differenct printers. So when the Lisp writes the Script I want it to setup the default printer for the drawing to be the default "windows" printer that is assigned to their computer.
Justin,
to get the default printer in the active layout
(setq aclyt (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object))) lytplt (vla-get-ConfigName aclyt))
and the windows default printer
(setq win "HKEY_CURRENT_USER\\Software\\Microsoft\\Windows NT\\CurrentVersion\\Windows" dev (vl-registry-read win "Device") winplt (substr dev 1 (vl-string-search "," dev)))
You'll probably have to redefine the KEY depending on the OS...
HTH
Henrique
