Visual LISP, AutoLISP and General Customization
lisp function as macro?
12 REPLIES 12
Message 1 of 13
The_Caddie
758 Views, 12 Replies
I use the following lisp to navigate through my toolpalettes
(command "*_TOOLPALETTEPATH" "C:/path/to/My/atc/file")
Is it however possible to do this using a macro instead?
Thanks-
12 REPLIES 12
Message 2 of 13
pendean
in reply to: The_Caddie
Are you an LT user, or wish to do so for an LT user?
Message 3 of 13
BlackBox_
The OP clearly states that they use the above LISP... Besides, what does that even matter, given the question?
Macro:
^C^C*_TOOLPALETTEPATH;"C:/path/to/My/atc/file";
"How we think determines what we do, and what we do determines what we get."
Message 4 of 13
The_Caddie
Nope its not for lt, its for a vb.net program. the marcro will help prevent the user having to restart the autocad program when changes are made.
if done as a lisp the autocad  program needs to restart the system to reload the lisp 🙂
Message 5 of 13
BlackBox_
No... It doesn't have to... It just needs to call LOAD on said LISP file to reload the code.
Message 6 of 13
pendean
in reply to: BlackBox_
You don't need to know: get over it 🙂
Tags (1)
Message 7 of 13
pendean
There is no lisp file: see original post and code shared, and need from the OP http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/lisp-function-as-macro/m-p/3935407#M3...
Tags (1)
Message 8 of 13
BlackBox_
in reply to: pendean
I'm going to disregard your juvenile response this time, as I think you're confused, pendean.
Firstly, there's LISP code in the original post of this thread (which the OP said they use in a Tool Palette), and your initial post is to ask about LT?
AutoCAD LT doesn't support LISP, nor VB.NET which the OP clearly stated this is for in the link you just posted.
@ The_Caddie -
Your inquiry may be better suited for the .NET Forum instead.
You see there's no need for LISP, or Macro at all if you're using .NET API, as you could instead easily use a SendStringToExecute() call within your custom CommandMethod, or Tool Palette Control's Button Object's Click event(s). *Going from memory*
Message 9 of 13
BlackBox_
@BlackBoxCAD wrote:
Firstly, there's LISP code in the original post of this thread (which the OP said they use in a Tool Palette)...
Correction... The OP said they ''use the [abovementioned] lisp to navigate through [their] toolpalettes."
Like a wise man once taught me... I prefer clarity to agreement.
Separately, it would be great if users could actually modify their posts, to correct typos, etc. beyond the +/-2 minutes after their post (like every other CAD Forum allows)... You can do better, Autodesk, I believe in you.
Message 10 of 13
pbejse
Good luck with that BlackBox, Been there, done that. 😄
Maybe you'll have more influence than the rest of us. Perhaps more nagging form the forum members  and the moderators will finally give-in somehow.
pBe
Message 11 of 13
hmsilva
in reply to: pbejse
pBe
Off-topic
I fully agree!
Cheers
Henrique
Message 12 of 13
BlackBox_
in reply to: pbejse
pBe
More influence than the Expert Elite... And just why would you think something like that?
I'm just a newbie.
Message 13 of 13
BlackBox_
My apologies to The_Caddie; hopefully a moderator can split this unintended tangent into a separate thread.
That is all... Carry on.
*Heads down range to draw fire*
”Boost
