Visual LISP, AutoLISP and General Customization
Lisp for removing last characters of block name in selected object ?
22 REPLIES 22
Message 1 of 23
shehab10
2092 Views, 22 Replies
Hi, When i export revit drawing with revit family
the revit family become block in autocad like this
M_Single-Flush - 700 x 2200mm-278353-Ground Level _0_45
usually i want to remove the ID and view name to become like this without have to re type because it is tedious
something like how many letters you want to remove from last to first ?
or something better like remove this last two dash and the letters embedded inside ( that separate name-ID-View name)  -278353-Ground Level _0_45?
22 REPLIES 22
Message 21 of 23
Kent1Cooper
in reply to: shehab10
If you can stand to have the word " Diameter" left in as part of the round-dining-table Block name, it looks like everything would have the pattern that you want to remove all characters starting at the second hyphen from the end.  That's the only thing resembling any kind of pattern that I can see in them, that a generic routine would be able to work with and come up with a consistent kind of change.  If that would always be the case in other Block names not listed here, a routine could be made to do that.
Kent Cooper, AIA
Message 22 of 23
shehab10
in reply to: Kent1Cooper
BlackBox_ or someone could you provide me the final version that rename all blocks that end mm or m as well as prfix m_?
Message 23 of 23
shehab10
The code working but I just want the code to make changes on multiple selection instead of one by one as i attached in the previous sample dwg.
”Boost
