Visual LISP, AutoLISP and General Customization
Lisp- create block, insert that block
9 REPLIES 9
Message 1 of 10
m_rogoff
3152 Views, 9 Replies
I am trying to make a Lisp that will create a Block from ALL objects in a drawing. I would like the name to be exactly the same as the Dwg name (without the ".DWG" extension) with an "X" after. Then I need to insert this block back at 0,0 (when I run the -BLOCK command, the objects disappear upon creation of the block). I was using this expression to get the Dwg name, I just need to add an "X" at the end.
(substr (setq dwgname (getvar "dwgname")) 1 (- (strlen dwgname) 4))
So drawing "S1.DWG" will have a block called "S1X" with the pickpoint placed at 0,0
9 REPLIES 9
Message 2 of 10
Use "strcat" function
Eg: (strcat "S1" "x") will return "S1X"
Message 3 of 10
I found a lisp that will get me close (attached)
I do not want to have to enter each specific dwg file name. I want it to automatically grab the name of a random file, as I have Many to do.
Message 4 of 10
Hello....
      I have modified your attached file which saves the block with the drawing name....Try it.
Note that I didnt understand your requirement completely. Hope this serves your purpose
Message 5 of 10
hmsilva
in reply to: m_rogoff
Hi m_rogoff,
perhaps something like this
(vl-load-com)
(defun c:demo (/ file) (setq file (strcat (vl-filename-base (getvar 'DWGNAME)) "_X")) (if (tblsearch "BLOCK" file) (command "_.-block" (setq file (strcat file "X")) "0,0" "_All" "") (command "_.-block" file "0,0" "_All" "") ) (command "_.insert" file "_S" 1 "0,0" "") (princ) )
Hope that helps,
Henrique
Message 6 of 10
m_rogoff
in reply to: hmsilva
Both iterations work well.
Thank you very much for your help
Message 7 of 10
hmsilva
You're welcome, m_rogoff
Glad I could help
Henrique
Message 8 of 10
You are welcome Smiley Happy
Message 9 of 10
m_rogoff
Henrique,
   I chose your routine becuase the language is simpler and easier for me to understand. However, I need to add two additional lines and I am having trouble figuering out where to merge these commands into your lisp. Where would I add the following lines? Thanks
(command "-layer" "m" "S-Hardware" "c" "2" "" "s" "0" "")
(command "_.chprop" "all" "" "layer" "S-HARDWARE" "c" "bylayer" "lw" "bylayer" "")
Message 10 of 10
hmsilva
Hi m_rogoff,
add those commands just after the
Henrique
”Boost
