Visual LISP, AutoLISP and General Customization
LISP: Check for Workspace
5 REPLIES 5
john.laidler
7577 Views, 5 Replies
I'm having difficulty with this, and need some help.
What I need is to check to see if a specific workspace is created, and if so set it.  It not, then return with an error message.
I'm having trouble with accessing the already created workspaces, and verifying that the workspace is created.
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
5 REPLIES 5
dbroad
in reply to: john.laidler
(getvar "wscurrent") will give you the current workspace.  I would definitely check that first.
After that you might look at this thread
Architect, Registered NC, VA, SC, & GA.
BlackBox_
Do you have to iterate the existing workspaces provided by Main/Enterprise CUI(x), or is a simple T, or Nil returned value sufficient?
(defun _WSCURRENT (workspace)
  ;; Example:
  ;; (_WSCURRENT "YourWorkspaceNameHere")
  (not (vl-catch-all-error-p
         (vl-catch-all-apply 'setvar (list 'wscurrent workspace))
"How we think determines what we do, and what we do determines what we get."
BlackBox_
in reply to: dbroad
If obtaining a list of existing workspaces is essential, methinks it would be simpler, certainly more efficient, to instead employ a .NET LispFunction Method to return such, taking a single string argument (the CUI[x] to cull).
Cheers
john.laidler
in reply to: BlackBox_
Thanks... this is exactly what I needed.
John Laidler
BlackBox_
You're welcome; I'm happy to help.
Cheers :beer:
”Boost
