(defun fReSetOsM ( )
(setvar "osmode" 0 )
(princ)
(defun fAddOsMode ( value )
(setvar "osmode" (logand (logior (getvar "osmode") value) 16383))
(princ)
commands az and ac are working
(defun C:az ();;set osmod to 0
(fReSetOsM )
(defun C:ae ();;add to osmod , endP
(fAddOsMode 001 )
Where is the wrong in the syntax of command ace that is not working?
(defun C:ace ();;add to osmod , Circle , endP
(fReSetOsM )
(fAddOsMode 002 )
(fAddOsMode 001 )
(fReSetOsM )
Try
(defun C:ace ();;add to osmod , Circle , endP (fReSetOsM ) (fAddOsMode (+ 001 002)) (fReSetOsM ) )
EDIT: if 'Circle' is Center should be 004 instead of 002, 002 is for midpoint.
Henrique
(fReSetOsM )
(fAddOsMode 002 )
(fAddOsMode 001 )
(fReSetOsM )
Could it be simply that it includes (fReSetOsM) at the end? Whatever comes before that is undone by that.
