Hello all, I have this problem with this basic autolisp code. I wanted to link the longitude and lattitude of my autocad project with the same location on google map for a quick reference. so i wrote this
(defun C:googleMap ( )
(setq googleMap "https://maps.google.com/maps?q=loc:32.746635,-97.319549")
(startapp "explorer" google)
the code works with other urls like "https://maps.google.com" but not with this specific kind of url
it throws this error message
"There is no program associated to perform the requested action. Please install a program or, if one is already installed, create an association in the Default Programs control panel.
appreciate any help
Solomon Tessema
Solved by rkmcswain. Go to Solution.
Try the following:
(defun C:googleMap ( / filename shell) (setq filename "https://maps.google.com/maps?q=loc:32.746635,-97.319549") (setq shell (vla-getinterfaceobject (vlax-get-acad-object) "Shell.Application" ) ) (vlax-invoke-method shell 'Open filename) (vlax-release-object shell) )
Or you can change the code to use the SH command placing quotes around the URL:
(defun c:googlemap () (setq googlemap "Explorer \"https://maps.google.com/maps?q=loc:32.746635,-97.319549\"")(command"_SH" googlemap))
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
This is great, but shouldn't the code grab the location you select onscreen? I knew AutoLisp years ago but haven't used it recently. I'll keep looking.
