Visual LISP, AutoLISP and General Customization
Linetype Lisp???
8 REPLIES 8
Message 1 of 9
396 Views, 8 Replies
Linetype Lisp???
Is there a lisp routine that will maintain the linetypes after you've
changed the objects to layer 0?
Let me explain: We receive a lot of architectural files and I need to
temporarily import the objects into my drawings. I don't like to bring in
all of their layers and generally change the objects from the original layer
to layer 0. However, when I do this the linetypes are "By Layer" and all
change to Continuous. I'd like to maintain the linetype from it's original
layer state after I place them into layer 0.
Thanks for any help.
- Tom C.
8 REPLIES 8
Message 2 of 9
Try GO-0.LSP from
http://www.turvill.com/t2/free_stuff
It moves everything in a drawing to Layer 0 while retaining all assigned
colors and linetypes, whether originally set explicitly or bylayer.
___
"Tom C." wrote in message
news:2E28BF87F29D2A343009A8D0430B980C@in.WebX.maYIadrTaRb...
Message 3 of 9
Thanks for the link Paul.
Unforntunately, I'm using Acad 2000 and the routine gets an error somewhere
in the first part of setting up the layers. Do you have a version for 2000?
I'm not too good with lisp and don't know how to tweak the code.
- Tom C.
"Paul Turvill" wrote in message
news:BBB807B5F7C7E3EF3AC3F19ECACF5522@in.WebX.maYIadrTaRb...
> Try GO-0.LSP from
> ___
Message 4 of 9
Actually, the lisp routine had a variable in the wrong spot.... I can send
the 'fixed' one to you if you like... but it does not retain linetypes...
only colors.
If you wanna do it yourself find the line that reads: (third line of the
actual program):
"._layer" "_S" "0" "_T" "0" "_c" _conorm "0" "_f" "~0" ""
and change it to this:
"._layer" "_S" "0" "_T" "0" "_c" "8" _conorm "_f" "~0" ""
news:8B82DC728D594947D5C56E8249F834A3@in.WebX.maYIadrTaRb...
somewhere
2000?
> Thanks,
> - Tom C.
> > Try GO-0.LSP from
> > ___
Message 5 of 9
Thanks Casey.
I replaced the line you gave and it worked as you said - only colors. Is
there a way to add the linetype variable in there?
- Tom C.
"Casey Roberts" wrote in message
news:534AA00E4045EB2B1C2659F5A4C3249A@in.WebX.maYIadrTaRb...
> only colors.
> actual program):
> somewhere
> 2000?
> > Thanks,
> > - Tom C.
> > > Try GO-0.LSP from
assigned
> > > ___
you've
Message 6 of 9
My apologies, guys ... I thought I had uploaded the latest version of GO-0
to the site. Here's an updated one that works in A2K+ *and* handles
linetypes.
___
news:05E62C9354446BDA67BA04F6D47E31A9@in.WebX.maYIadrTaRb...
> Thanks Casey.
Message 7 of 9
(don't forget lineweights!)
> Thanks Casey.
> Regards,
> - Tom C.
send
linetypes...
> > only colors.
> > actual program):
> > somewhere
> > 2000?
> > > Thanks,
> > > - Tom C.
> > > > Try GO-0.LSP from
> assigned
> > > > ___
> you've
Message 8 of 9
Easy enough for anyone to add, if they want to...
___
"Peter Friedrich" wrote in message
news:8C17061B00B6A9062E9A41213D542EF7@in.WebX.maYIadrTaRb...
Message 9 of 9
neilcooper33
Hi
Sorry, i realise that this thread is really old.... been trying to find theversion of the lisp which does the linetypes too, are you able to post it please?
thanks in advance 🙂
N
”Boost
