Hi all,
I'm doing a little "house cleaning" of some old code this morning and I ran across one so old that I cannot remember what it's for.
(COMMAND "LINE" "FROM")
I run it but it only seems to take more clicks than it's worth. Can anyone remember what the from option is for? It must be FROM before my time 😉
Thank you
@mid-awe wrote:
Hi all,
(COMMAND "LINE" "FROM")I run it but it only seems to take more clicks than it's worth. Can anyone remember what the from option is for? It must be FROM before my time 😉
Thank you
Hi mid-awe,
it's not an option "from" the line command, it's the osnap "from"...
The osmap "from" lets you create a temporary base point with the option offset.
Try it, using shift right click.
Henrique
@mid-awe wrote:Hi all,
Thank you
It is an "object snap"/command modifier that provides a method of offsetting a point a given distance and angle from a selected point... from the help files:
At a prompt for locating a point, enter from, and then
enter a temporary reference or base point from which you can specify an offset
to locate the next point. Enter the offset location from this base point as a
relative coordinate or use "direct distance entry"
It can come in handy from time to time... if you want to start a line (per your example but there are many applications for it) six units away from a given point on something else then you would type "from", pick the reference point then type "@10,0,0" (or drag your cursor in the "X" direction and type 10 with DDE) to have your point located 10 units along "X" from the selected reference point.
-Gary
Thank you all. Now the messages @ the command prompt make sence I would not have guessed that in a million years. It's been long enough that I don't remember using it for anything.
Thank you both for clueing me in.
