I know that for layers ON/OFF in current open dwg file, I should use:
[I just want to On/Off for my "STAMP" layer]
(COMMAND "LAYER" "ON" "STAMP" "")
(COMMAND "LAYER" "OFF" "STAMP" "")
but I have more than 150 dwg file and I should open all of dwgs one by one and setting ON/OFF for STAMP layer for every drawing and it takes so much time! 😞
is there any solution for my question?
I just want to select files and LISP program set the STAMP layer to ON or OFF value.
can anybody help me?
Thanks.
Solved by pbejse. Go to Solution.
@aqdam1978 wrote:Hi,
Thanks.
On or Off? which one is it? On if its off? and vice versa?
Hi pbejse,
the first step is OFF.
In fact I need two lisp program, one for OFF and one for ON!
But there are 99% similiar!
if I have OFF lisp, so I will have ON lisp too!
@aqdam1978 wrote:Hi pbejse,
We can use ODBX. only "drawback" is you loose the thumbnail preview. but its not a big deal. when you open the file and save you will get it back
These are the supporting sub funcitons
(defun Get_Folder (/ sObj cFold fobj oval sto fto) (setq sObj (vla-getInterfaceObject (vlax-get-acad-object)"Shell.Application") cFold(vlax-invoke-method sObj 'BrowseForFolder 0 "Select Folder for Layer Files" 512)) (vlax-release-object sObj) (setq fObj(vlax-get-property cFold 'Self) oVal (vlax-get-property fObj 'Path)) (foreach sto (vl-directory-files oval "*.dwg") (setq fto (cons (strcat oval "\\" sto) fto)) ) (vlax-release-object cFold) (vlax-release-object fObj) fto ) (defun _OnOffLayer (ln doc m) (if (not (vl-catch-all-error-p (setq la (vl-catch-all-apply 'vla-item (list (vla-get-layers doc) ln))))) (vlax-put la 'Layeron m)) ) (defun _Odbx (fileNames ln m) (cond ((and (setq myDoc (vla-GetInterfaceObject (vlax-Get-Acad-Object) (strcat "ObjectDBX.AxDbDocument." (substr (getvar 'AcadVer) 1 2)))) (foreach File Filenames (if (not (vl-catch-all-apply 'vla-Open (list myDoc file))) (progn (_OnOffLayer ln myDoc m) (vla-saveas myDoc File) ) ) T ) (vl-catch-all-apply 'vlax-Release-Object (list myDoc)) ) ) ) )
(vl-load-com)
and this are the commands
(defun c:ons ( / Files) (if (setq files (Get_Folder)) (_odbx files "STAMP" -1)) (princ) ) (defun c:ofs ( / Files) (if (setq files (Get_Folder)) (_odbx files "STAMP" 0)) (princ) )
You can change the layer name to your liking
HTH
