Hi Rakesh,
This should help you. I hope all functions are present as I grabbed them
from a larger application.
Thanks to Tony Tanzillo for one of the functions as noted.
Don Butler
Donald E. Butler
donaldebutler@netzero.net
REQUIREMENTS: AutoCAD ver 2000+
OBJECT: Save and Restore Layer States compatible with AutoCAD's Layer
Manager.
SUBR's: (lsave name bit)
(lrestore name)
(ldelete name)
Layer Bit Settings Bit Value
All layer properties================== 65535
Color================================= 32
Frozen or thawed====================== 2
Linetype============================== 64
Lineweight============================ 128
Locked or unlocked==================== 4
New viewport layers frozen or thawed== 16
None================================== 0
On or off============================= 1
Plotting on or off==================== 8
Plot style============================ 256
(vl-load-com)
;;;Author: Tony Tanzillo
(defun LayerGetObject (ProgId / Result)
;; First try using explicit version-dependent progid:
(setq result
(vla-getinterfaceobject
(vlax-get-acad-object)
(strcat ProgId "." (substr (getvar "acadver") 1 2))
;; Else try the version-independent progid:
(if (not result)
(setq result
progid
result
(setq *lsman* (LayerGetObject "autocad.acadlayerstatemanager"))
(vla-setdatabase *lsman* (vla-get-database (vla-get-activedocument
(vlax-get-acad-object))))
(defun lsave (nam bit)
(setq nam (strcase nam))
(if (member nam (getstatenames))
(vl-catch-all-apply 'vla-delete (list *lsman* nam))
(vl-catch-all-apply 'vla-save (list *lsman* nam bit))
(prompt (strcat "\n" nam " Saved"))
(princ)
(defun lrestore (nam)
(if (member (setq nam (strcase nam)) (getstatenames))
(progn (vl-catch-all-apply 'vla-restore (list *lsman* nam))
(vl-cmdf "_.regenall")
(prompt (strcat "\n" nam " Restored"))
(princ)
(defun ldelete (nam)
(progn (vl-catch-all-apply 'vla-delete (list *lsman* nam))
(prompt (strcat "\n" nam " Deleted"))
(princ)
;;;Utility Return Saved States
(defun getstatenames (/ nams dict obj)
(setq dict (vla-getextensiondictionary
(vla-get-layers
(vla-get-activedocument (vlax-get-acad-object))
(if (not
(vl-catch-all-error-p
(setq obj (vl-catch-all-apply
(function (lambda () (vla-item dict "ACAD_LAYERSTATES")))
(vlax-for n obj
(setq nams (cons (strcase (vla-get-name n)) nams))
(if nams
(acad_strlsort nams)
"Rakesh Rao" wrote in message
news:4051B924.4060606@4d-technologies.com...
> Hello,
> I have written a small command to Save and Restore layer states using
> Lisp. I am using the native AutoCAD Layer command driven by (command...)
> to perform the save and restore. My question is - how do I control the
> various options in the layer state dialog which appear in the dialog
> box? Secondly, when I restore a previously saved layer state, the
> current layer is not correctly updated. Any help is appreciated.
> Regards
> Rakesh
> AutoCAD customization for Engineering/Mapping/GIS
> Get GeoTools @ http://www.4d-technologies.com/geotools
> Build MyGeoTools @ http://www.4d-technologies.com/geotools/my_geotools.htm
> FREE downloads : http://www.4d-technologies.com/techcenter
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.591 / Virus Database: 374 - Release Date: 2/17/2004
