Visual LISP, AutoLISP and General Customization
layer name with spaces in a menu macro
6 REPLIES 6
rrebich
600 Views, 6 Replies
I am trying to change the color of a layer using a menu macro. The layer name contains a space, which I think is the problem. If I type this string at the command line:
(command "-layer" "c" "7" "ipco border$0$line1" "")
the layer color changes properly, but when I use the same string in a menu macro and run it from a button, the command fails. Any help?
Ross
6 REPLIES 6
EC-CAD
in reply to: rrebich
You can execute Lisp from your menu Macro.. just do:
^c^c(command "-layer" "c" "7" "ipco border$0$line1" "");
... as your Macro
Bob
rrebich
Hi Bob,
I tried that exact macro and the command failed. It works from the command line, but fails as a macro. Could it be the space in the layer name?
Ross
EC-CAD
Most likely the $ rather than the space.
Make sure you have quote marks around the Layername.
Another way might be to :
^c^c(setq lay "ipco border$0$line1")(command "-layer" "c" "7" lay "");
Bob
rrebich
You're probably right about the $, but still no luck with the macro. I'm getting a syntax error. I appreciate the help, though.
Ross
EC-CAD
Cut/Paste your Macro..as it is now.
Bob
EC-CAD
Got it. It's the $ character .. chr 36 .. that's doing it.
Try this Macro:
^c^c(setq lay (strcat "ipco border" (chr 36) "0" (chr 36) "line1"))(command "-layer" "c" "7" lay "");
Bob
”Boost
