I'd like to add Layer descriptions , but I cannot seem to get out of the "D"escription option when the script runs so I get the some crazy descriptions. Is there a special key stroke to get to the next line to "M"ake a layer?
As far as i know you need to apply the description to the name after the layer has been made. so it prompts you for the name of the layer to apply the description to. basically needing to enter the layer name twice.
I'm not sure if your just adding descriptions to current layers or adding new ones.
attach your script if you can. Thanks.
This seems to work for me for creating new ones
-layer
M
name
D
lyrdescription
name
-layer
M
name2
D
lyrdescription2
name2
And this one for existing layers
-layer
D
changeddescription
name
y
-layer
D
changeddescription2
name2
y
this is a sample scr to create a layer named "123", in color "3" and a description "test123", and a layer
named "456" in color "5" and a description "test456"...
layer
n
123
n
456
c
3
123
c
5
456
d
test123
123
d
test456
456
I hope it helps
Henrique
I guess this is my problem I'm creating a long list in Excel, concatanating then saving to SCR.
What I have been doing is adding the _layer to the top.
Could you give it a peak? Maybe you see the error of my ways.
Thanks Henrique.
I notice I picking up some random double quotes when I save the excel to txt?
Hi Joseph,
just removing the double quotes, and formatting your txt, it works fine.
Henrique
Joseph,
after some testing, I think the problem is solved.
you have to put \ U+000D (carriage return), after the layer description
and before the layer name, without spaces between them.
See the attached file, I did't change your configuration,
just add \+U000D
Hope that helps you...
Henrique
One more thing
if you need to create layers with spaces in name just place the layer name with double quotes:
layer
n "Concrete Walls" c 5 "Concrete Walls" d All Concrete Walls\U+000D"Concrete Walls"
n "Aluminum Windows" c 2 "Aluminum Windows" d All Aluminum Windows\U+000D"Aluminum Windows"
n "Aluminum Doors" c 1 "Aluminum Doors" d All Aluminum Doors\U+000D"Aluminum Doors"
Cheers
Henrique
Joe,
as you can see, using \U+000D in the concatenating formula, with no spaces between
(F3)&"\U+000D"&TRIM
such this
="N "&TRIM(B3)&" C "&TRIM(D3)&" "&TRIM(B3)&" LT "&TRIM(C3)&" "&TRIM(B3)&" D "&TRIM(F3)&"\U+000D"&TRIM(B3)
It works well
Got an error when you try to load a linetype that I have not “SANITARY”.
I think it is working well
See the attachments:
Cheers
Henrique
We can't see the layer description in the Layer Properties Manager DB after importing las file.
We have followed the below mentioned steps.
We have attached a snap for your reference.
Las File Contents:
0
LAYERSTATEDICTIONARY
0
LAYERSTATE
1
A
91
1023
301
Sample
290
0
302
0
8
MEP
90
8
62
5
370
18
6
Continuous
2
Color_5
8
Str
90
8
62
2
370
30
6
HIDDEN
2
Color_2
8
Arch
90
8
62
1
370
5
6
CENTER2
2
Color_1
8
0
90
8
62
7
370
-3
6
Continuous
2
Color_7
RNDPIS,
in Layer Properties Manager, you can't export or import the layer description, this is none of the available properties... One possible way, is with a script file. Attached is a .txt file [isn't possible to attach a .scr file], rename the file to .scr, and in a new dwg, type at the command line scr, and select the sript file, it will create the layers with all the settings including the descriptions, that you had in your example...
Hope that helps
Henrique
Thanks for your valuable suggestion. It is a nice tips.
But here we have to write the scr file. Is there any process to export the scr (as las export) file from a AutoCAD drawing including layer description so that we can import the scr file to another AutoCAD file as per our requirements.
Thanks again for your quick response.
RNDPIS,
as I said
"in Layer Properties Manager, you can't export or import the layer description, this is none of the available properties... "
Another solution is,
Select all the layers in the layer manager, then to copy to clipboard, then paste into Excel. Then use a concatenating formula [see message 9] to create a scr.
Or a simpler way
Command: ADCENTER -> will open the Design Center, browse for the dwg which contains the layers, click in the layers to expand, select all the layers and drag to your dwg, it will create all the layers, with all the settings including the descriptions in your dwg...
Hope that helps
Henrique
Thanks for your quick reply.
We have created a scr file and when we have executed the file then a list box (see the attach sample.png) wiil come.
Here we have attached the text file (instead of scr file)for your reference. Please rename it in .scr file.
RNDPIS,
this is because the command was not terminated, after the last text line, you have to add two empty lines [enter, enter], to end the layer command
i.e.
n D c 158 D L HIDDEN D LW 0.13 D d DD\U+000DD
<- empty line
<- empty line
Henrique
Make your own layers in excel With script command and directly paste in autocadhttps://docs.google.com/spreadsheets/d/1FYgMsiDtIICqFnRWWBj5LpTmDvgtFy2r/edit?usp=drivesdk&ouid=1040...
