I would like to have a macro command for LAYDEL. I have this (below) but want to make a change. Now, I pause for user input to select the desired layer to delete. I have to then hit ENTER and Y ENTER manually. I would just like to select the objects, hit ENTER once, and have it finish the Y ENTER automatically.
^C^Claydel;\;y;
Command: LAYDEL
PAUSE FOR USER INPUT TO MANUALLY SELECT OBJECT Select object on layer to delete or [Name]:
Selected layers: S-ARCH.
Select object on layer to delete or [Name/Undo]:
******** WARNING ********
You are about to delete layer "S-ARCH" from this drawing.
THIS IS WHERE THE HANGUP IS Do you wish to continue? [Yes/No] <No>: y
Deleting layer "S-ARCH".
1 layer deleted.
Solved by Shneuph. Go to Solution.
Your macro works for me without getting hung up. AutoCAD 2014.
What is MENUECHO set to?
